I found a stream on websote and managed to snatch mpd and downloaded mp4 file. but when i download m4a file to 100% it just ends up being 1 kb in size. any help?
Heres the MPD
Code:https://d418svx2ag8gc.cloudfront.net/8482/EncodedVideo/uploads/movie_stream/full_movie/190634/stream.mpd
youtube-dl gives a ~54 MB file
Code:youtube-dl.exe --fixup never -f audio_und_mp4a https://d418svx2ag8gc.cloudfront.net/8482/EncodedVideo/uploads/movie_stream/full_movie/190634/stream.mpd
downloaded fine for me
https://we.tl/t-GbOjYUGPirCode:Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41/iso5/iso6) File size : 53.8 MiB Duration : 55 min 13 s Overall bit rate mode : Constant Overall bit rate : 136 kb/s Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : enca-40-2 Duration : 55 min 13 s Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 50.7 MiB (94%) Default : Yes Alternate group : 1 Encryption : Encrypted
ffmpeg messed that up, if I'm not mistaken I told you in private message to move ffmpeg to another folder before downloading
there's another solution to this and that's written in the post above
you should use the --fixup-never parameter when downloading so that will prevent ffmpeg from messing up the m4a
Lossless conversion between M4A and AAC (with many files)
By Robbo in forum AudioReplies: 6Last Post: 16th Mar 2021, 21:19 -
tool to check video files for freezes? (downloaded with letmeatit)
By schmutzbrust in forum Newbie / General discussionsReplies: 12Last Post: 8th May 2020, 18:47 -
Format of the bbc iPlayer video downloaded files
By fbmate in forum Video Streaming DownloadingReplies: 3Last Post: 9th Apr 2020, 06:23 -
problem converting .m4a to .aac files
By alex5908 in forum AudioReplies: 48Last Post: 8th Sep 2019, 21:40 -
Editing software for downloaded video files.
By Kmroc in forum EditingReplies: 1Last Post: 3rd Feb 2017, 08:51
