Results 1 to 14 of 14
  1. If yes, why? Where can I point to any written standard anywhere that would help me prove this is correct?
    Thanks!
  2. Member DB83's Avatar
    Jul 2007
    Where do you get this crazy idea from ?
  3. I'm a Super Moderator johns0's Avatar
    canada
    Videos can be weird sizes now a days due to cell phones,ive been getting 960x1872 videos but i bet the op meant 640x352 so it's 360p.
  4. Member DB83's Avatar
    Jul 2007
    Ok.
    For the OP in this scenario one would look to consider if the 640*352 gave a true 16:9 image which it presently does not. So 640 / 16 * 9 = 360. Thus 360i/p
  5. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    If it's a cellphone video, sure you could call 352*640 360p or 352p. But even before cellphones people would call 1080p content in the movie industry 2k (DCI), as the picture was 2048 horizontal. Unlike 1920x1080 which is called 1080p. Basically it doesn't matter and there are no clean rules as these are mostly marketing terms. Like with HD, FHD, UHD.
  6. Why don't you just call it 352x640? Or 640x352? Why bother with imprecise abbreviations?
    (You should always show the resolution as width:height.)
  7. The reason I'm asking is because there is an online persoonhood registry based on blockchain called Proof of Humanity. In it, you submit a video and make a deposit. If the registry is not challenged, you get registered and the deposit is returned to you.
    If you get challenged, because of not following guidelines, you go to a "trial" and if you loose you loose your deposit (around $500) which goes to the jurors and the challenger.
    The guideline says that videos should be 360p, and there are some videos that are being challenged for being 352*640 pixels with the argument:
    "Registry policy states ""The video quality should be at least 360p..."" This video is 640 x 352, which is less than 360p."
    So there's got to be some hard documentary evidence somewhere that could help make a case that these allegations are false. First because there is a misinterpretation of what 360p and then for the lack of consideration that common peoplo submit their videos by sending them to themselves via whatsapp which then encodes the video to that size.
    So any help is appreciated!!!
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    well technically 352 is lower than 360. so just because you upload a sideways video doesn't mean you get to break the rules. "video" has always been measured horizontal not iphone idiot vertical trash.
  9. But the reason 8 pixel-wide columns were extracted from top and bottom is because the codec AFAIK cropped them to fit the macroblock size of 16*16 in a h264 codec. Am I right? Would you consider it NOT 360p because of 8 pixels?
  10. Originally Posted by ludovico View Post
    There's your answer. If the body you are submitting it to has said explicitly they do not consider it 360p, then for their purposes (and yours) it is not.
    (FWIW YouTube defines 360p as 640x360.)
  11. Codecs can pad internally. So there's no reason you can't have 360 pixel wide/tall frames (it will be padded to 368 and the extra 8 pixels will never be displayed).
  12. Member Cornucopia's Avatar
    H264 can have macroblock sizes of 4x4, 4x8, 8x4, 8x8, 8x16, 16x8, and 16x16. 360->352 to accommodate an assumed codec requirement is a mistake.
  13. Video Restorer lordsmurf's Avatar
    Why? WTF?
    If I said that a turd coming out of my ass had blockchain, people would line up to buy my poop.
    I just do not understand this nonsense.
  14. Member DB83's Avatar
    Jul 2007
    ^^ Sounds like a classic grift.
    Get some mug to send a deposit and find an excuse not to repay it.
