Hello,
I have a weird situation going on where video inputs are getting reversed when combining 2 different mp4s of a user who was disconnected in a meeting.
The person was disconnected because of a momentary internet outage.
video1 is the first video of the user before the disconnect.
video2 is the second video after the user reconnected.
Again the issue is that I expect the new video to play video1 followed by video2 but that is not what is happening here. video2 plays followed by video1.
video 1 has a start time offset of 465013 and a stop time offset of 646003.
video 2 has a start time offset of 975433 and a stop time offset of 4300863.
I know a simple solution would be to just reverse the inputs, but this is an automated process so I am trying to understand how the inputs need to work so I can adjust my scripts. Also, the person could be disconnected more than once.Code:ffmpeg \ -loop 1 -framerate 30 -t 465.013 -i /assets/img/filler640480.jpg -i video1.mp4 -y \ -loop 1 -framerate 30 -t 329.43 -i /assets/img/filler640480.jpg -i video2.mp4 -y \ -f lavfi -t 0.1 -i anullsrc=channel_layout=mono:sample_rate=48000 \ -filter_complex " [0:v]scale=640:480,setsar=1[v0];[1:v]scale=640:480,setsar=1[v1];[2:v]scale=640:480,setsar=1[v2];[3:v]scale=640:480,setsar=1[v3];[v0][4:a][v1][1:a][v2][4:a][v3][3:a]concat=n=4:v=1:a=1" -vsync 2 -vcodec libx264 -pix_fmt yuv420p user1-camera-grid.mp4
Never tried this, but looking at https://trac.ffmpeg.org/wiki/Concatenate I would have expected there to be some mapping ('-map') after the concatenation,.. so that might be something to try. (also have you tried using '-vsync drop' instead of '-vsync 2' ?)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Use ffmpeg to switch between 2 rtmp inputs having different profiles
By regstuff in forum Video ConversionReplies: 0Last Post: 12th Apr 2019, 10:51 -
ffmpeg order of operations - scaling footage and interlacing
By nesburf in forum Video ConversionReplies: 12Last Post: 31st Jan 2017, 17:40 -
Complex conversion of tv recordings using ffmpeg
By agni451 in forum Video ConversionReplies: 0Last Post: 9th Oct 2016, 19:34 -
FFmpeg version with both - libfaac and subtitles filters?
By Anvil2k12 in forum Video ConversionReplies: 1Last Post: 8th Aug 2016, 03:49 -
Apply Yadif using complex filter in FFmpeg
By panzerIV in forum EditingReplies: 4Last Post: 5th Jul 2016, 04:14
