  1. Could someone help me make a bat file to make a program close down then start again, or maybe restart is the term
    I have the start part, what goes before it?
    @echo off
    Start "" "C:\Program Files (x86)\myprogram.exe"
    Isn't the echo off supposed to stop the black command window opening? I have another bat file and the window stays open. It has the echo off
    edit: I see the echo off is not to stop the window opening. How do you stop it opening or make it close.
  2. Kawaiiii
    May 2021
    Italy
    echo off simply disable the command echo-ing.. so every line in the batch file doesn't echo itself in the terminal window. It has the @ before to avoid to echo-ing in the command window itself
    If the program starts correctly the command window should close automatically.
    To kill a process, then relaunch it.. you can try:
    taskkill /IM myprogram.exe
    Start "My Program" "C:\Program Files (x86)\myprogram.exe"
  3. Originally Posted by krykmoon View Post
    Thanks. Would the taskkill /IM myprogram.exe have the full path like the start?
    I find if i don't have "" between start and the path it just get a command windows with the path to the folder the bat file is in
    I just checked my other bat file the window does close actually
  4. Kawaiiii
    May 2021
    Italy
    No, since it's the program "image" name (the name it has like a process).
    If there are multiple instances of the same program or programs with the same name running.. to avoid conflict you should specify the specific process PID (and use /PID option instead)
  5. Originally Posted by krykmoon View Post
    OK I see
    OK I got it working except the GUI stays open. I need the code equivalent of clicking the _ to minimise to the task bar
