My car's GPS is updated by SDHC card, now at version 11. Packaging states, "Warning! The card in this package is write protected. It cannot be used in any other device."
I have older versions 6 & 9 SDHCs (all FAT32) I would like to reuse, but the Warning seems to be true--so far.
"Properties (ReadyBoost): The device is mounted read-only. This usually happens with write-protected devices/media or when BitLocker group policy settings prohibit write access to non-encrypted removable devices."
I've tried using diskpart & regedit fixes often suggested, after confirming the write-protect switch is at "off." None work.
BitLocker doesn't seem to be a factor, based on other utilities' analyses.
I hate to toss an otherwise good SDHC that's readable in my Win10 PC and other devices.
Any other options?
try this - with the card connected to your windows pc open the command prompt (cmd)
type diskpart and hit enter, Type the following command and hit Enter each time: list disk, select disk # (# is the number of your write-protected SD card.) attributes disk clear readonly wait for the process to complete - https://www.easeus.com/partition-master/how-to-format-a-write-protected-sd-card.html -
If you have access to a MAC or Linux machine sometimes reformatting it in those devices will work. Did that years ago in my then Linux media player for a card like that. Then reformatted again in my PC
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
On Windows, try HPUSBDisk https://download.cnet.com/HP-USB-Disk-Storage-Format-Tool/3000-2094_4-10974082.html. It's meant to force format flash drives, but I've used it on SD cards in a USB adapter. I have to Run as administrator on Win 10.
Can "hunting" Comcast Motorola DVR be put in "playback only" mode?
By Jimw338 in forum Newbie / General discussionsReplies: 3Last Post: 14th Mar 2021, 12:48 -
Will a JVC VCR "Stop" Playback if the video is "too grainy" or degraded?
By timepassenger in forum Capturing and VCRReplies: 8Last Post: 2nd May 2020, 07:17 -
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 07:25 -
Use "Line in" or "Microphone" jack as audio output.
By DonSeenu in forum AudioReplies: 3Last Post: 14th May 2018, 03:23 -
"Drag" transparent images over moving footage with a "mouse"
By theatermajorindistress in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2017, 12:48
