I have tried to rip a music concert DVD to video using a whole host of different well known software. I always get the same results.
When I play the original DVD on my TV/AV receiver, the main vocals come from the centre channel, as expected, but when I play back the video on the same system, the main vocals do not appear on the centre channel, but on front left and right. The centre channel just contains backing vocals and one instrument.
All six channels are present. To confirm this, I loaded the video file into Adobe Premiere Pro and also Audition. They both confirm my observations above.
I'm totally baffled by this. Any ideas please?
Alan
Results 1 to 20 of 20
I tried every possible combination of options but couldn't get it to work. It's not exactly user friendly is it? It's also dated 2014 which doesn't exactly fill me with confidence.
Thanks anyway. -
Yes it's copy protected, but aren't all commercial DVD's copy protected?
Anyway, my original point was that I've tried so many different DVD rippers and they all manage to get round the protection but fail to replicate the original DVD 5.1 track layout for some reason. -
OK. I ripped the VIDEO_TS folder and managed to extract the ac3 audio as you mentioned. However the centre channel is exactly the same as all the other attempts I've made.
I'm totally baffled by this. Why is it different to the DVD? I'm afraid I have to concede defeat. -
I suspect two things:
1. The player might be downmixing from 5.1 to 2.0.
2. Audio stream was muxed with a problematic muxer.
You can play the dolby 7.1 or dts 5.1 sound check files available at The Digital Theater to verify if your player is downmixing to stereo.
If the player is downmixing, perhaps it can be configured to disable downmixing.
If the player is not downmixing the audio, then I recommend demuxing all audio streams from the VOBs with DGIndex, and muxing only the 5.1 audio stream plus the video stream with mkvtoolnix-gui or mkvmerge. But don't use ffmpeg to mux to mkv. I had many issues with audio when I muxed to mkv with ffmpeg, and zero issues with audio when I muxed to mkv with mkvtoolnix-gui or mkvmerge.Last edited by codemaster; 7th May 2021 at 14:16.
codemaster,
I'm using the Plex client on a Samsung TV. Sound gets to the AV receiver using ARC. It's definitely not downmixing as other videos play correctly.
DVD's play OK with audio on the correct channels. The test videos also play OK. The problem occurs when ripping some DVD's.
I tried your suggestion of using DGIndex on the VOB's. Exactly the same results as all of the other extractors I've used.
The center channel contains no main vocals and instruments that appear on the front speakers on the DVD appear on the rear speakers when playing the ripped video.
This is confirmed by loading the files into Audition or Premiere Pro and examining the six channels.
Alan -
I think I'm finally getting to the bottom of this! The DVD is shown as having 5.1 audio. Ripping software also shows it has 5.1 audio tracks.
As an experiment I ripped it with just stereo audio tracks. Playing this on the TV gives me identical audio to the original DVD.
It's definitely 6 channels. Main vocals are in centre only and all other instruments and effects are in the correct places.
Can you explain why? How does this work? -
Dobly Pro Logic?
This is the first time you mentioned a separate stereo track -
Sorry, I wasn't aware that's how Dolby Pro Logic works. That explains why the VOB's only contain two channtls. All six channels encoded into two.
Pro Logic II hides multi-channel surround audio inside a stereo AC3 track. Pro Logic-capable playback devices can detect this and reconstruct the multi-channel audio. Other devices will play it as stereo.
Pro Logic II takes a stereo source and applies processing to expand it to simulate 5.1 audio.
Possible solutions:
1. The stereo AC3 track can be upmixed to 5.1, and a new 5.1 AC3 track can be created and then used with Plex.
2. If instead of Plex, you use the Samsung video player app and a usb drive, and if the remote has a "PL II MODE" button, you can press that button to change the mode. There are 5 modes: music, cinema, prolog, matrix, stereo, music. Maybe the "matrix" mode will upmix to 5.1.
3. Watch it in stereo, which is exactly what I do with concerts, because they sound much better with headphones than with speakers.Last edited by codemaster; 7th May 2021 at 21:55.
codemaster,
I already have the solution. Don't try and rip a 5.1 DVD into a video format with 6 discrete channels. That's where I went wrong.
I should have ripped it in stereo and let my AV receiver decode the 5.1 channels.
Thanks to all who replied.
Alan
Have I captured my Mini-DV:s correctly?
By Tunanisse in forum Capturing and VCRReplies: 8Last Post: 4th Jan 2021, 23:36 -
Weird problem converting / extracting Marvel's The Avengers Blu-Ray
By EmmB in forum Video ConversionReplies: 0Last Post: 8th Jun 2019, 22:31 -
Issue extracting subtitles from DVD with VSRip
By Vitality in forum SubtitleReplies: 3Last Post: 17th Oct 2018, 15:00 -
Extracting the image of a button from a DVD menu
By Traction557 in forum Authoring (DVD)Replies: 14Last Post: 25th Nov 2016, 12:23 -
Problem extracting Audio Tracks from MKV files
By RandomNewbe in forum Newbie / General discussionsReplies: 6Last Post: 19th Jul 2016, 03:30
