    Aug 2018
    Miami Florida
    I would like to know, if the Output Clips from Lossless Cut, can be Imported Into, and used in a Conventional Video Editor.
  2. Kawaiiii
    May 2021
    Italy
    Lossless Cut Editor doesn't change the format of the original file you cut..
    So if you can edit the original (uncut) file in your video editor .. it will be the same with the output generated by Lossless Cut Editor.
    Aug 2018
    Miami Florida
    Thanks for your Help Krykmoon!
  4. Kawaiiii
    May 2021
    Italy
    You're welcome : )
    It's undoubtedly a very handy utility, Lossless Cut Editor: simply to use, fast and reliable.
