  1. Hi all,
    I've been scouring the net for an answer to this. Given a 7.1 DTS-HD MA source and using ffmpeg to convert to AC3 (5.1 is maximum supported by ac3 codec), if I just simply use
    ffmpeg -c:a ac3 -b:a 640k
    will it downmix the 7.1 to 5.1 properly? I've seen on the net that people generally specify the channels to get 5.1 like:
    ffmpeg -c:a ac3 -b:a 640k -ac 6
    I ran both on the same source file and the resulting ac3 files actually had different hashes (but same filesize), which makes me think there is a difference. I wonder if i've been sub-optimally converting the DTS audio in the content i've been working with lately (though the resulting audio files sound the same to me).
    Anybody know the answer?
  2. DECEASED
    Jun 2009
    Heaven
    Use eac3to with the option "-down6" instead of ffmpeg.
    "Programmers are human-shaped machines that transform alcohol into bugs."
  3. Not likely but check ffmpeg logs to be sure - most probably core part (5.1) is selected and used directly by ffmpeg - downmixing from 7.1 to 5.1 can be performed explicitly but probably you will need to specify donwmixing matrix manually (and perhaps apply additional processing like delay/phase shift).
  4. Thank you for the information!
