Try StreamFab All-in-One and rip streaming video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
  1. Hello, I'm sorta new to Vapoursynth and looking how to get rid of DotCrawl, but I'm not exactly how to go around that with my script. I'm encoding from a telecined and interlaced anime DVD for measure too.
    There seems to be some dot crawling left as seen here:
    [Attachment 58736 - Click to enlarge]
    My Vapoursynth script is as follows:
    import vapoursynth as vs
    import fvsfunc as fvf
    import vsTAAmbk as taa
    import functools
    import mvsfunc as mvf
    import havsfunc as haf
    core = vs.get_core()
    def postprocess(n, f, clip, deinterlaced):
       if f.props['_Combed'] > 0:
          return deinterlaced
       else:
          return clip
    def decimate(src):
        src = core.vivtc.VFM(src, 1)
        return core.vivtc.VDecimate(src)
    def detelecine(src):
        matched = core.vivtc.VFM(src, 1)
        src = core.nnedi3.nnedi3(src, field=1)
        return core.std.FrameEval(matched, functools.partial(postprocess, clip=matched, deinterlaced=src), prop_src=matched)
    src = core.ffms2.Source(r"E:\Anime\VideoFile.m2v")
    src = decimate(src)
    src = detelecine(src)
    src = fvf.Depth(src, 16)
    src = src.std.CropRel(left=12, right=12, top=0, bottom=0)#crop off any black borders, number need to be even
    Trim = core.std.Trim(src, first=0, last=1000) #first and last frame for the clip you want to cut
    scaled = core.resize.Spline36(Trim, 720, 540) #slight upscale to get it back to normal resolution
    denoise = mvf.BM3D(scaled, sigma=[5,1.5])
    dehalo = haf.HQDeringmod(denoise, darkthr=0, sharp=0, mthr=56)
    aa = taa.TAAmbk(dehalo,aatype='Nnedi3', cycle=1) #smooths out artifacts related to interlacing or bad edges
    out = aa
    final = fvf.Depth(out, 8)
    final.set_output()
    I'm not sure where how use a Dot Crawl removal line here. I installed this plugin called DotKill but I wasn't sure how to include it in properly. I added it in as
    dotkill = core.dotkill.DotKillT(src, order=0, offset=1, dupthresh=128, tratio=3, show=False)
    but I didn't see any dot crawl removed.
  2. If you need help you might want to share a small sample of your unprocessed source,..
    Assuming you properly called that script part, have you checked with that your settings catch your dot crawlers?
    Did you read the documentation ? (https://github.com/myrsloik/DotKill/blob/master/README.md)
    users currently on my ignore list: deadrats, Stears555
  3. Member hydra3333's Avatar
    Oct 2009
    Australia
    Ooh, thank you for that link.
