I am getting issue on SunNXT while requesting key from notaghost's wvkeys site.
MPD : https://suntvvod.s.llnwi.net/movies/ce54e7fed2437ab83854acfa56b1fc54/132819/132819_hd....nXtGW1Qx/uLg==
License URL : https://www.sunnxt.com/content/license/?content_id=132819
Headers : User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:97.0) Gecko/20100101 Firefox/97.0
Accept: */*
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip, deflate, br
Content-Length: 5723
Origin: https://www.sunnxt.com
Connection: keep-alive
Referer: https://www.sunnxt.com/malayalam-movie/detail/132819/jan-e-man?carouselAction=Latest%20Movies
Cookie: XSRF-TOKEN=eyJpdiI6InZnQzJJcTFcL0pZUExLdmRac25Ka2FBPT0i LCJ2YWx1ZSI6ImY0dEVvUFlHcXNDK3JlMHFrekRUb21zMzM2QW xKdWhaMXl4SVhJY1JUWERsYVdDcGtLM1dYWW9GYXJUSjR4UG9D VXR6S2twSzVnWkJmUVF2RnJXaWVBPT0iLCJtYWMiOiI3MGEzZT g5MWFjODgzNWRhZjY3ZmFmNWI3NDJiZTBjYTUzZDc3NDQ5ZGE1 MzExNzM5YmUwYTdiMWJmN2UzZjFkIn0%3D; laravel_session=iossWHnOVuD6ah14k7pwzMtyBmTYbhufwy Ew29xM; RT="z=1&dm=sunnxt.com&si=63db8e41-bf2c-4c27-a168-9c91aa5a27f2&ss=l03wqaxb&sl=1&tt=1nm&bcn=%2F%2Fbea con.s.llnwi.net%2Fstarling%2Fbeacon.txt&ld=1nn"
Sec-Fetch-Dest: empty
Sec-Fetch-Mode: cors
Sec-Fetch-Site: same-origin
TE: trailers
Closed Thread
Results 1,951 to 1,969 of 1969
Thanks, that's a good explanation. Yes I can see it first requests the certificate like you say. Do you have any idea why my licence requests fail to this server with tools like getwvkeys, wks-keys etc.? What should I do to make it work then? Is it because server only accepts encrypted requests? If so, is there a way to modify existing scripts to do that?
with wks header cookie like this exampleCode:
WidevineDecryptor: Found key: 789b4cb771e270d255f0884cca8628f0 (KID=9d656054c01756e991d4e0bdf5eb43f9) WidevineDecryptor: Found key: 20dbaf5b79bcbf92e80a5696d41659b6 (KID=32ce79a9dd32522a8d79102bdf7c1384) WidevineDecryptor: Found key: 157ad8f0041f35e6044dfbeeedf83019 (KID=3f6468e14c9357c6a1100f619af1b613)
try with those datasCode:cookie: _ga=GA1.2.XXXXXXXX; WZRK_G=c7242CCCCCCCCCC; _gid=GA1.2.3XXXXXXXXX; _gat=1; laravel_session=WNIXXXXXXXXX; WZRK_S_WW6-54K-855Z=%7B%XXXXXXXXXXXXX; RT="z=1&dm=sunnxt.com&si=3XXXXXXXXXXXX"; XSRF-TOKEN=eyJpdiXXXXXXXXXX
Hi, everyone. I wanted to have a go at https://getwvkeys.cc/ in order to get the keys of the videos of a national streaming site.
I have a manifest file as an example because I don't know what constitutes as header and license.
I also don't know what to look for in the debugging window on Firefox when searching for the license server.
(Fortunately, I learned how to get the PSSH from reading this thread, it's in the contents of the manifest between <cenc
ssh>.)
The video is part of a paid streaming service.
Anyway, here's the link:
https://opto.sic.pt/#/play?sid=MTI6NTU5MGU2MDdjZjdmNGE4NzhjNmRjZWQ0MWNhMjE2NGE%3D&sNam...AyODZmZg%3D%3D
If you have read how to get the pssh, then you must have overlooked how to get lic url
A reminder:
Under Network tab in DevTools filter url for words like: WV, lic, widevine, auth, drm, etc
Type your word in FilterURL > Refresh stream (F5) > get video playing
If no results > repeat with different word > F5 again > get video playing
It may / may not have a long string attached to it, if it does, use this in your keys challenge
Once you have established the lic url, in FF, right click on the link in the debugger, select copy > copy as cURL (Windows)
open curlconverter.com
copy the content into left window > Py result is returned in right hand window > this is your headers.py for WKS-keys
WKS-Keys (with a working L3 cdm) - pssh + lic url + headers.py = keys
Notaghost getwvkeys online http://getwvkeys.cc/ - pssh + lic url + basic format headers = keysLast edited by codehound; 2nd Mar 2022 at 17:31.
Many thanks for that detailed explanation!
It actually worked; using getwvkeys online, I managed to get key 1.d5bf5bd73d162f4e0ec9166c54cb0b0c:9d29d4090053991 7a363f669967cd2af
Using mp4decrypt, I discovered that the working part of the key was 9d29d40900539917a363f669967cd2af.
However, this only worked for the MP4 video file that I had downloaded using yt-dlp and the add-on "The Stream Detector" for Firefox. The audio, an M4A file, can't be decrypted using either "d5bf5bd73d162f4e0ec9166c54cb0b0c" or "9d29d40900539917a363f669967cd2af". Not even changing the number of the key (key 1:, key 2:, and so forth) could accomplish the decryption of the audio.
EDIT: I found out that the original audio extension was "mp4a" instead of "m4a". I changed the file extensions in mp4decrypt and it worked perfectly.Last edited by tugatomsk; 2nd Mar 2022 at 18:13. Reason: found the reason
Charming........
For decryption use:
then merge with ffmpeg:Code:mp4decrypt.exe --key kid:key "encrypted-video.mp4" "decrypted-video.mp4" mp4decrypt.exe --key kid:key "encrypted-audio.aac" "decrypted-audio.m4a"
Code:ffmpeg -i "decrypted-video.mp4" -i "decrypted-audio.m4a" -c copy "output.mp4"
That's strange... the next episode of the show I'm trying to decrypt - the follow-up to the video I had just successfully decrypted - has the exact same license and PSSH, which results in the same keyID and decryption key. This shouldn't be the case, right? Therefore, I can't decrypt the next episode...
What am I missing?
Strip Playready and Widevine DRM
By freaknik in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jun 2024, 15:20 -
Decoding manifest.mpd (Widevine)
By WaitForIt in forum Video Streaming DownloadingReplies: 6Last Post: 7th Jun 2021, 13:44 -
getting widevine CEK key
By netbreak in forum Video Streaming DownloadingReplies: 1Last Post: 19th Feb 2018, 12:03 -
Looking for anyone with Google Widevine knowledge.
By cookeri6 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2017, 13:33 -
By cookeri6 in forum Video Streaming DownloadingReplies: 0Last Post: 15th May 2017, 12:45
