Closed Thread
Results 1,801 to 1,830 of 1969
request URL generates a header to get the keys from server. so i am requsting json data from request url with the help of athuthendication and x-token payload values from secure url. after request i get n1 and custom data values from request url i use this as header to get keys. json generated token expires in 30 secs so with header.py values have to get keys before 30 seconds else server will reject ur request.
NOTE: i am talking about zee5
https://vimeo.com/676738192
have a look and the time before 30 sec s u will get key after 30 u wont
try faster
zee5 download with WKS
(custum works only for zee5. i am newbie in python any upgrade help will be appreciated)
l3.py code
ENTER Default KID example : 4cd2e2f0-c0dd-4b08-9f9e-9f96631c4555
input url is request urlCode:# -*- coding: utf-8 -*- # Module: KEYS-L3 # Created on: 11-10-2021 # Authors: -∞WKS∞- # Version: 1.1.0 import base64, requests, sys, xmltodict import headers from pywidevine.L3.cdm import cdm, deviceconfig from base64 import b64encode from pywidevine.L3.getPSSH import get_pssh from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt def get_pssh(keyId): array_of_bytes = bytearray( b'\x00\x00\x002pssh\x00\x00\x00\x00') array_of_bytes.extend(bytes.fromhex("edef8ba979d64acea3c827dcd51d21ed")) array_of_bytes.extend(b'\x00\x00\x00\x12\x12\x10') array_of_bytes.extend(bytes.fromhex( keyId.replace("-", ""))) return base64.b64encode(bytes.fromhex(array_of_bytes.hex())) kid = input("Please input KID in hex string: ") kid = kid.replace('-', '') assert len(kid) == 32 and not isinstance(kid, bytes), "wrong KID length" pssh = "{}".format(get_pssh(kid).decode('utf-8')) lic_url = 'https://spapi.zee5.com/widevine/getLicense' def WV_Function(pssh, lic_url, cert_b64=None): wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic) widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=headers.headers) license_b64 = b64encode(widevine_license.content) wvdecrypt.update_license(license_b64) Correct, keyswvdecrypt = wvdecrypt.start_process() if Correct: return Correct, keyswvdecrypt correct, keys = WV_Function(pssh, lic_url) print() for key in keys: wv = key.split(":") print('WidevineDecryptor: Found key: {1} (KID={0})'.format(wv[0],wv[1]))
example :
Code:https://spapi.zee5.com/singlePlayback/getDetails/secure?content_id=..........
double click copy all the results and paste here with new file name generateheaders.py
replace x-access-token and Authorization value from request url Payload
copy the results to headers.py and save itCode:import requests import re import json url = input("url : ") payload ={"x-access-token":"rvGZ68.....Q","Authorization":"bearer vEKe7B....."} r = requests.post(url, json=payload) value = r.json() result = json.dumps(value) print(result) wv = result.split('"') n1=(len(wv)-22) sdrm=(len(wv)-26) print('headers = {{ "nl": "{0}", "customdata": "{1}" }}'.format(wv[(n1)],wv[(sdrm)]))
CHECK HEADER it looks like
now run l3.py and enter only KIDCode:headers = { "nl": "XXXXXXXXXXX", "customdata": "XXXXXXXXXXXX" }
hope u get the keys
goodluck
i donno any info about json headers. i know only for zee5
NOTE: please some one help me with the upgraded script to make it more easier Thanks in advanceLast edited by demon; 14th Feb 2022 at 00:38.
@ell0 wrote
This made me laugh. I can say with absolute certainty that if someone told you right now how to get this working, tomorrow some budding genius will ask the same question.And I say, wouldn't it be better if you told us how so that we don't have to bother people every time they want to get the keys to some content of channel4Last edited by jack_666; 13th Feb 2022 at 23:02.
I used wvdump on a Nexus 7 tablet running Android 10 (LOS). I got two folders: key_boxes and private_keys. The first folder contains 4445.bin and 4445.json and the other folder has client_id.bin and private_key.pem.
I went to https://github.com/medvm/, downloaded the python scrupt, renamed client_id.bin to device_client_id_blob and renamed private_key.pem to device_private_key and placed them in the devices/android_generic folder.
I went on RTE Player and got the mpd and license url and entered them into the medvm script. The thing is I get the same five keys everytime no matter what programme I try.
Could someone tell me what step I did wrong? Not sure if the Nexus 7 tablet is the problem since it had Android 10. Or whether I need the files from key_boxes....
Its all about replicating what the browser does.
https://imgur.com/yD8xmG7
the broswer sends a POST request to "https://spapi.zee5.com/singlePlayback/getDetails/secure?......." with 2 parameters in json format
{"x-access-token":"eyJ0eXAiOiJqd3QiLCJhbGciOiJIUzI1NiJ9.eyJw. .....","X-Z5-Guest-Token":"309Kc9nb14.........."}
(the fields are slightly different for a paid subscription compared to free)
https://imgur.com/BxWn9dS
the server responds with a lot of information, but the most important ones are nl and sdrm.
nl and sdrm are used as headers in the request to the license server with the license challenge from wks as the payload.
As demon mentioned, the nl and sdrm tokens are only valid for less than 30seconds, so you need to capture the response from the 1st request to the "getDetails/secure" url, parse it, and copy it to the headers.py file before sending the normal wks license request.
Confirmed, working.
I asked this a couple of months ago and they sent me all the keys in a text document.
[Attachment 63371 - Click to enlarge]
Strip Playready and Widevine DRM
By freaknik in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jun 2024, 15:20 -
Decoding manifest.mpd (Widevine)
By WaitForIt in forum Video Streaming DownloadingReplies: 6Last Post: 7th Jun 2021, 13:44 -
getting widevine CEK key
By netbreak in forum Video Streaming DownloadingReplies: 1Last Post: 19th Feb 2018, 12:03 -
Looking for anyone with Google Widevine knowledge.
By cookeri6 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2017, 13:33 -
By cookeri6 in forum Video Streaming DownloadingReplies: 0Last Post: 15th May 2017, 12:45
