Closed Thread
Results 1,711 to 1,740 of 1969
man can u help with this
api url
license urlCode:https://api-a0.marrow.com/v3.1/gtoken/android/NUxBTkkrSHF4dUgwbVVZTG9OaWxMMXVLQU1tVlpkaW1vN3d4TEx5THQ3STBNN2poMmlkUFJKN2lzZTlYLzBRcjdhSi9NeVMxZXZmbHR1RnRHMG9YVncvWi9OOUkydzRhQ2lpc2svZXdCZjg0MTlpemhqaTVQb0FIU0ZpOERON1FDZkwvajBPaVVIcmVvalBWaW15Q0NyS25yZ0s2YzRlenFUT1Zqbk4rTlhIWWZRdkdseWRCdmhpVGVRRERZR0xMWUlkbDZUSVcwWHRyQWdESkhJWUFPWWJSRmlsSDdCRDRaMlVFTnVHUjFhejlxR3JGTmRDYmd5Ti9lZU9kSFBaNVdLZmg2WGxzcDFtOUxXYkQzbDh0enRSZ3V4UnB3SjhROVlCRVYzLzc4cWxGMlR4dTJBWVMyZkF0b0VvdEJBNlpleXI3aWxGTHJvMXY4aTFNZ2J3eDh2az0=
mpd urlCode:https://drvideo.keydelivery.mediaservices.windows.net/Widevine/?kid=fd74a351-a387-4084-a0aa-cda6c4bab4a1
psshCode:https://drvideo-ak.akamaized.net/video-sg2/bd75c35f-e24c-45cc-8212-e466c266d3c8/5943.ism/manifest(format=mpd-time-csf)
headersCode:AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEP10o1Gjh0CEoKrNpsS6tKE=
Dr-Platform: android
Dr-Dv: m.2061a6e23daeed98
course-id: 1
Dr-UID: 6197bdf7aa8ded1766241523 - MFREE
Dr-App: marrow
Dr-Dv-ENC: UDW/ko7L7tq1MvPm2kCcQUP0XgcaqMjZ8B0v+yyMej815hq1NyWkIx QtiW1Wl4Wipg==
Dr-Dv-Model: M2007J17I
Dr-Token: .eJxVzNEKgzAMheF3ybUM285UfZmSLREKakoc7mLs3ddNGHj75 T95QcoMI6Ab4o2nSNSzsIuI_uo6H6ABtsSy57vUbLn4Fh2h-MAkwkN_BGWmx6S21IRWNq0_f06lfFdkps-_pF1sy7rWS2i7g3U7Kbw_1GEvnA.FMs7Jg.9eq3YKTPQtkoo-XmXHkiwryATzM
Dr-App-Version: 308
Dr-Dv-Ts: 1644268191446
Content-Type: application/octet-stream
User-Agent: Marrow/7.15.1 (com.marrow; build:308; Android 11(30); Device)
Accept-Encoding: gzip
Content-Length: 2114
Host: api-a0.marrow.com
Connection: Keep-Alive
please show me how to use curl api for this
help me i have been trying in vain for 4 months?????
Kind of a hail mary here. The license server I'm trying to get keys from is spitting this out:
Have tried a myriad of things, starting from adding "licenseData" as one of the lic_field_names fields in l3.py (widevine-keys of course) and other things, can't get it to work. Would be grateful for any help. Admittedly I am a python noob so maybe this is something very simple that I'm not able to recognize or implement, perhaps base64 related. Decoding the string via base64 shows text very similar to raw license responses I've seen elsewhere.{"licenseData":["CAISqAIKNAoQv1GeqGe1O7h3D1UCWfPHC..."]}
The l3.py error is:
File "l3.py", line 121, in <module>
correct, keys = WV_Function(pssh, lic_url)
File "l3.py", line 116, in WV_Function
wvdecrypt.update_license(license_b64)
File "C:\Users\Admin\Desktop\widevine_keys-main\wvdecryptcustom.py", line 58, in update_license
self.cdm.provide_license(self.session, license_b64)
File "C:\Users\Admin\Desktop\widevine_keys-main\cdm\cdm.py", line 270, in provide_license
license.ParseFromString(base64.b64decode(license_b 64))
File "C:\Users\Admin\AppData\Local\Programs\Python\Pyth on37\lib\base64.py", line 80, in b64decode
s = _bytes_from_decode_data(s)
File "C:\Users\Admin\AppData\Local\Programs\Python\Pyth on37\lib\base64.py", line 46, in _bytes_from_decode_data
"string, not %r" % s.__class__.__name__) from None
TypeError: argument should be a bytes-like object or ASCII string, not 'list'Last edited by magicsp00n; 8th Feb 2022 at 11:05.
@magicsp00n
You need to parse the json to array in the py script, the pull the license data out from array. You should also redact that license response as it contains unique identifying (encrypted) information relating to the cdm you used - this could potentially lead to it being revoked.
Thanks for the heads up about the license response info.
I've now fixed the json parsing of the response with a little bit of help from someone more knowledgeable than me and now this come up
The licenseData is parsed correctly now but this comes up. Not sure what the problem is to be honest. I should mention that there's a series of required json fields for the request, which I've hardcoded, one including a licenseChallenge. I've hardcoded it to the l3.py and it can get a license response but I'm thinking that the challenge originating from a browser and l3.py using an android CDM to process the response might be a reason why it's not working, not entirely sure though.PSSH obtained.
AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEPFKZn P3Ds+wWYpDGS1YM0lI88aJmwY=
license response status: <Response [200]>
File "l3.py", line 108, in <module>
File "l3.py", line 103, in WV_Function
File "C:\Users\Admin\Desktop\widevine_keys-main\cdm\cdm.py", line 285, in provide_license
session.session_key = oaep_cipher.decrypt(license.SessionKey)
File "C:\Users\Admin\AppData\Local\Programs\Python\Pyth on37\lib\site-packages\Cryptodome\Cipher\PKCS1_OAEP.py", line 167, in decrypt
raise ValueError("Ciphertext with incorrect length.")
ValueError: Ciphertext with incorrect length.
You might have toasted your CDM. Do you have another one to try?
I failed too many times with license request on udemy and this happened.
You can thank ElCap for the toast phrase. It's perfect. Even though he first used it for my poor little CDM baby.
I propose a change for revoke. Everyone, please start using toasted instead of revoked.
[ss]vegeta wrote
I think a better idea is to coin the term vegetaYou might have toasted your CDM. Do you have another one to try?
You might have vegeta your CDM.
vegeta will be immortalized.
hi, i'm trying to download from blimtv
i know that uses the same KID:KEY so... what's the problem?
D:\python bad37.py --url https://www.blim.com/asset/13084 -c playready
VIDEO - Bitrate: 5805kbps - Profile: H264 - Size: 1.87GB - Dimensions: 1920x1080
AUDIO - Bitrate: 160kbps - Profile: AACL - Size: 52.85MB - Language: es-la
Name: Teresa S01E01 - Salir de pobre
Teresa S01E01 - Salir de pobre [1080p].mp4
100%|█████████████████████████████████████████████ ███████████████████████████████████| 279/279 [00:53<00:00, 5.25it/s]
Done!
Teresa S01E01 - Salir de pobre (es-la).mp4
100%|█████████████████████████████████████████████ ███████████████████████████████████| 279/279 [00:04<00:00, 60.17it/s]
Done!
No subtitles available.
Muxing...
Error: The type of file 'Teresa S01E01 - Salir de pobre [1080p].mp4' could not be recognized.
Done!
anyone know something?
thanks in advance
I also suspected that but I just played the bitmovin demo on my phone (where I got my keys from) and it plays. The site I'm trying to get keys from is really finnicky it seems like.
Thanks for that tidbit, someone also pointed me in that direction, tried it and it spits out "mismatched DeviceID".This also comes up if you're using the hardcoded CAES message instead of your own to make the request. Make sure you replace it with the one generated by yourself (with wvdecrypt.get_challenge()).
Seems like whatever challenge widevine-keys is sending doesn't take into the account my device's details. I just noticed there's a deviceconfig.py file, is that what I have to edit to fix the challenge? If so, how and where do I get the exact details? deviceconfig.py seems like a summary of the devices in cdm\devices, I only have the generic_android folder and I overwrote my blob/key over the ones already there, not sure if I should've moved my CDM files in a different way and it's why it's now screwing up.license response status: <Response [403]>
server reports: {"errorReason":"10062","description":"Mismatch in request information - Device","message":"DRM DeviceID Mismatch"}
server did not issue license, make sure you have correctly pasted all the required headers in the headers.py. Also check json/raw params of POST request.
What's with the sass? Anyways, I see what you're saying now, thought CDMs were revoked in their entirety rather than specific for one site, thanks for that tidbit. I just tested playing a video on the Android app of the site I'm trying to get keys from, using the same phone where I got my CDM from, and it plays so I don't think it's that. How do you think I should go about solving the mismatched DeviceID error widevine-keys spits out that I described earlier? Appreciate the help.
Peacock needs scripting, you cant just copy+paste the headers as there appears to be a "one time" token being used, meaning once Chrome makes a request to the license server and the video starts playing, you can't just go sending more license requests using the same token and headers etc... you need to request a new token from their api, then make another call for a license using that token.
Are you sure about that? Is that the only problem with Peacock?
By the explanation you gave, last time I saw something like that was some NBA site.
What I did then, was using debugger to stop the license exchange at some point (OPTIONS I think), before the video starts playing, and was able to get the one time token and use it to get the key.
Just spent the last 7 hours trying to dump keys from an old Samsung tablet and from an x86 virtual machine. No luck. And from what I've read in this thread, the platform isn't easy to work with once the keys are obtained. Can someone reach out to me privately and help point me in the right direction? I know it's possible...
I came across this amazing learning platform Upgrad, i was wondering if i could download the videos in my laptop
URL to one of the videos is this
https://players.brightcove.net/4744899836001/default_default/index.html?videoId=5207449446001
Note: This code will work only in FireFox, if you want to make a webpage to load this video, you may use this code
<!DOCTYPE html>
<html lang="en" >
<head>
</head>
<body translate="no" >
<video-js
id="bcplayer"
data-video-id="5670931150001"
data-account="4744899836001"
data-player="default"
data-embed="default"
data-application-id
class="video-js"
controls
playsinline
width="960"
height="540"></video-js>
<script src="https://players.brightcove.net/4744899836001/default_default/index.js"></script>
</body>
</html>Last edited by rana382; 10th Feb 2022 at 10:35.
I suspect that this may work.
License:https://manifest.prod.boltdns.net/license/v1/cenc/widevine/4744899836001/e9b925dd-efc4...M4ZDBlMWU3OQ==
PSSH:AAAAVnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADYIA RIQ+CkKpRxSRuCtIFtV+8Ne8RoNd2lkZXZpbmVfdGVzdCIIMTI zNDU2NzgyB2RlZmF1bHQ=
Headers:{'accept': '*/*', 'content-length': '316', 'Connection': 'keep-alive'}
f8290aa51c5246e0ad205b55fbc35ef1:5c99aaee06321edef 931999e9b5a33b3
pssh - from mpd
license url - from dev tools
key from - well, you know from where.
Can you please provide me more information here, which tool or application to be used here, it will be more helpful if you could attach any screenshots. as i tried using that url directly in browser but i did not work. i would really appreciate your help. Thanks in advance.
I tried that site too before like a year ago If I remember the problem has to do with the Identity Cookie or the AuthToken someone told me that the one I copied belong to browser cdm and I was using an android so I had to get the correct token from the android app also he told me if that's not the problem maybe was the cert.bin the site have so I couldn't make it work and I had to wait for the wv guesser to get the keys
Ha!
Like-minded individual, that guy...
[Attachment 63270 - Click to enlarge]
Followed all the posts and find out All4 is impossible for me to do it.
May I ask your guy for the KID:KEY of this one:
https://www.channel4.com/programmes/boobs/on-demand/72842-001
Also as I use n_m3u8dl-cli to download it, the videos and audios are ts files
They are merged to an unplayable mp4.
Is it correct to use mp4decrypt to decrypt this file or I need to decrypt the ts files?
in that case, how can I do it as there are so many files....
Strip Playready and Widevine DRM
By freaknik in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jun 2024, 15:20 -
Decoding manifest.mpd (Widevine)
By WaitForIt in forum Video Streaming DownloadingReplies: 6Last Post: 7th Jun 2021, 13:44 -
getting widevine CEK key
By netbreak in forum Video Streaming DownloadingReplies: 1Last Post: 19th Feb 2018, 12:03 -
Looking for anyone with Google Widevine knowledge.
By cookeri6 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2017, 13:33 -
By cookeri6 in forum Video Streaming DownloadingReplies: 0Last Post: 15th May 2017, 12:45
