Closed Thread
Page 46 of 66
FirstFirst ... 36 44 45 46 47 48 56 ... LastLast
Results 1,351 to 1,380 of 1969
  1. psaframe
    Mar 2021
    Algeria
    PM login info, I will help you if you want that of course.
  2. Originally Posted by D00oo00M View Post
    Originally Posted by momo26 View Post
    Hello guys,
    i'm tring to use the NotAGhost website API to extract keys from vdocypherbut wasn't successful
    i've used this code
    import requests,json
    api_url = "http://getwvkeys.herokuapp.com/api"
    license_url = "https://license.vdocipher.com/auth"
    pssh = "AAAAUnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADIiKnZkb2NpcGhlcjoyY2NkZmQ3YzRhOTQ0MDM2YjQxY2NmNTU3MzcyNTBjMUjj3JWbBg=="
    headers = {   "accept-language": "en-US,en;q=0.9",   "cache-control": "no-cache",   "content-type": "application/json",   "origin": "https://d2lrwez4x0gs00.cloudfront.net",   "pragma": "no-cache",   "referer": "https://d2lrwez4x0gs00.cloudfront.net/",   "sec-ch-ua-mobile": "?0",   "sec-ch-ua-platform": "Windows",   "sec-fetch-dest": "empty",   "sec-fetch-mode": "cors",   "sec-fetch-site": "cross-site",   "user-agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.93 Safari/537.36" }
    token = "eyJvdHAiOiIyMDE2MDMxM3ZlcnNJTkQzMTNhelpaZHlBcGxMaTlJQ2ljT21DendNZU1XR2hlSVBGVlFPTzc5Yk40MEVVamdCIiwicGxheWJhY2tJbmZvIjoiZXlKMmFXUmxiMGxrSWpvaU1XRTFNalUxT0dJell6QmhORE14Wm1FeVl6STFNRFkwWldFM01UZzBOVFVpZlE9PSIsImhyZWYiOiJodHRwczovL3d3dy52ZG9jaXBoZXIuY29tLyIsInRlY2giOiJ3diIsImxpY2Vuc2VSZXF1ZXN0IjoiQ0FRPSJ9"
    r = requests.post(api_url,headers=headers.headers ,json={"license":license_url,"pssh":pssh,"token":token}).text
    print(r)
    but i get this message
     {"Error": "Error Parsing JSON: unexpected EOF while parsing (<string>, line 0)"}
    any help please?
    open this
    https://getwvkeys.herokuapp.com/demo/vdocipher
    and write you pssh and submit.
    Edit: oh my mistake you want api...
    hello bro,
    yes i wanna use the API with Vdocipher website,
    thank you for the answer
  3. Please, who has "WKS-KEYS" saved, let me download it.
  4. Originally Posted by momo26 View Post
    hello bro,
    The getwvkeys website does not seem to have support for a key,value pair with the name "token", I don't think. If is not a header it seem like it would merge the license request and this token. Try using the following script which basically further help parsing the headers in the most lazy way possible. It would may help reduce these formatting errors as much as possible. save as 'getwvkeys.py'
    import requests, json, argparse, os
    aparser = argparse.ArgumentParser()
    aparser.add_argument('-p', '--pssh', help='content init data', required=True)
    aparser.add_argument('-l', '--license', help='license request endpoint', required=False)
    aparser.add_argument('--header', help='file with all the headers', required=False, default='headers.txt')
    args = aparser.parse_args()
    cached_endpoint = "cached"
    assert os.path.exists(args.header), 'headers file does not exists'
    if not args.license:
    	assert os.path.exists(cached_endpoint),'no license endpoint specifed or cached endpoint available'
    	with open(cached_endpoint, 'r') as handle:
    		args.license = handle.read()
    with open(args.header,'r') as handle:
    	file = handle.read()
    headers = {} #i don't like regex
    for line in file.split('\n'):
    	if line.startswith(':'): continue
    	key_pair, i = line.split(':'), 1
    	if len(key_pair) > 2:
    		headers[key_pair[0]] = ''
    		while i < len(key_pair):
    			headers[key_pair[0]], i = (headers[key_pair[0]] + key_pair[i] + ':'), i+1
    		headers[key_pair[0]] = headers[key_pair[0]][:-1]
    	else: headers[key_pair[0]] = key_pair[-1]
    	headers[key_pair[0]] = headers[key_pair[0]].strip()
    #filter uncesesary headers
    for name in ['content-length','sec-ch-ua',
    			'sec-ch-ua-mobile','sec-ch-ua-platform',
    			'sec-fetch-dest','sec-fetch-mode',
    			'sec-fetch-site', 'pragma', 'cache-control']:
    	if name in headers:
    		headers.pop(name)
    print('starting license request via getwvkeys to: {}'.format(args.license))
    resp = requests.post(
    	url="http://getwvkeys.herokuapp.com/api",
    	headers=headers,
    	json={"license":args.license,"pssh":args.pssh})
    assert resp.status_code == 200, 'key request failed\n' + resp.text
    try:
    	for key in resp.json()['keys']:
    		print('KEY:', key['key'])
    	print('decrypt with mp4decrypt')
    	cmd = "mp4decrypt"
    		cmd += " --key {}".format(key['key'])
    	print(cmd)
    except: print('failed parsing keys, server response:\n', resp.text)
    with open(cached_endpoint,'w') as handle:
    	handle.write(args.license)
    Then copy and paste all the headers from Chrome network's tab into a text file called headers.txt, save it on the same directory and then run the script like:
    python3 getwvkeys.py -p "your_pssh_here" -l "your_license_url_here"
    If that does not work post a screenshot of the headers from the Chrome Network tab and the Payload sub tab when doing a license request, you will want to hide some of the content of the token if you're concerned of your privacy.
  5. @EatThis
    Can you please show the format of the expected headers.txt as there are many opportunities for incorrect input. Does it need { }, commas at end, space at beginning .... ? There are numerous opportunities here. Kindly post a sample header.
  6. Originally Posted by jack_666 View Post
    @EatThis
    I went to justwatch.com (random website not streaming provider), but applies for any URL including the license request url. Open Dev Tools (Chrome) > Network > Click on the URL > Click on the Headers sub-tab > copied everything under "Request Headers". Pasted onto text file like this.
    :authority: www.justwatch.com
    :method: GET
    :path: /
    :scheme: https
    accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
    accept-encoding: gzip, deflate, br
    accept-language: en-US,en;q=0.9
    cache-control: no-cache
    cookie: a bunch of cookies here
    pragma: no-cache
    sec-ch-ua: " Not A;Brand";v="99", "Chromium";v="96", "Google Chrome";v="96"
    sec-ch-ua-mobile: ?0
    sec-ch-ua-platform: "Windows"
    sec-fetch-dest: document
    sec-fetch-mode: navigate
    sec-fetch-site: same-origin
    sec-fetch-user: ?1
    upgrade-insecure-requests: 1
    user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36
  7. psaframe
    Mar 2021
    Algeria
    hello bro,
    	if name in headers:
    		headers.pop(name)
    	headers=headers,
    try:
    	cmd = "mp4decrypt"
    	print(cmd)
    I keep trying with same error evry time
  8. Originally Posted by naim2007 View Post
    This response comes from the actual streaming service, what I suspect is that this website is expecting a JSON formatted payload with the license request in base64 like many websites do (Amazon, Apple Music/TV). The getwvkeys website seem to mainly apply when the license request is in bytes, getwvkeys generate the license request for you and send it to the streaming service. Without seeing how it actually interact with the website I can only speculate. This is an example of what I am looking for in the screenshot, this is using Paramount+ as an example. Without that, since I don't have access to such website, I am unable to know how and if can be fixed.
  9. Please, who has "WKS-KEYS" saved, let me download it.
  10. Anyone here successful at getting the free YouTube Movies?
    It seems like a very weird setup where they don’t just give you an easy to find mpd link.
    I found the mpd link with the view-source tool but then there seems to be no easy way to find the PSSH.
    EME Logger gives a string way too long to be a normal PSSH, there is no init.mp4 to get KID —> PSSH, and the PSSH isn’t listed in the mpd.
    I tried using a PSSH off the default KID of the video but it’s just “check protobufus”.
  11. Dear people,
    Hope you can help me out.
    I use Widevine-keys and on most sites it works flawlessly but now im trying canal digitaal nl and it does not work.
    It gets the pssh and it gets code 200 but does not show the keys and says my headers are wrong.
    But the funny part is with the same headers and license url etc https://getwvkeys.herokuapp.com/ does work i get the keys .
    The thing where i think it goes wrong is normally your browser does 3 request for a widevine license:
    OPTIONS,POST,POST.
    1st post is the server cert 2nd is the actual license.
    canal digitaal uses 2 requests options and the 2nd is the license allready they have put the server cert into their player.
    So my question is why does my tool now work and getwvkeys website does work ?.
    [Attachment 62837 - Click to enlarge]
    here it works
    [Attachment 62838 - Click to enlarge]
    here it does not.
    [Attachment 62839 - Click to enlarge]
    here are the headers i use .
    hope someone can help me out.
    maybe is because widevine-keys is altered version of wks-key ? i only have the widevine-keys tool that is still up on github the rest you guys talk about is gone there.
  12. I am not sure if I follow you correctly but if the last screenshot is the tool that is not working, is evidently clear the reason why. It should be doing a POST (requests.post) instead of requests.options. OPTIONS is done from the browser or service to know if the endpoint exists or learn what it support, it it exists it always will give you response core 200 but will never give you any data.
  13. Originally Posted by EatThis View Post
    yeah my bad but still when i do it correctly see below screenshots it does not work :S
    [Attachment 62840 - Click to enlarge]
    [Attachment 62841 - Click to enlarge]
    if i use the same info as above in https://getwvkeys.herokuapp.com/wv
    i get a key and kid.
  14. Originally Posted by Dazzler1985 View Post
    I see. How are you generating the license request, I mean the payload? The only thing I can think of is that the website is responding with the certificate. Which is often responded with if there is no license request payload.
  15. I am running into:
    Error 404:<br>{"code":190104,"message":"Status of response from Google Widevine server is not 'OK'."}
    Any ideas on what might be causing this error?
    Dec 2021
    Polska
    I'm still trying to get the keys from polsatgo / polsatboxgo and it still doesn't come out, try on getwvkeys.herokuapp.com, I get a message
    [Attachment 62854 - Click to enlarge]
    [Attachment 62855 - Click to enlarge]
    MPD:
    https://ipla-e2-19.pluscdn.pl/p/vm2dash/30/30f2614ee9a9f0e3575b8328d201d42c9673e19d/manifest.mpd
    Am I doing something wrong with the headlines? Could somebody help?
  17. Originally Posted by Adriano02 View Post
    MPD:
    Remove everything that is yellow . and try again
    [Attachment 62856 - Click to enlarge]
  18. Member
    Dec 2021
    Polska
    MPD:
    I deleted what I wrote and now such an error
    [Attachment 62858 - Click to enlarge]
  19. Originally Posted by Adriano02 View Post
    MPD:
    Hmzzz also remove content-type line then try again it should work then.
    If not check the license url again in your browser and screenshot te headers .
  20. Can anyone help with CTV, there are 3x keys but none of them seemed to work?
    Aug 2020
    Estonia
    Error
Name:	Screenshot 2022-01-10 at 21-07-40 Screenshot.png
Name:	Screenshot 2022-01-10 at 21-06-15 Screenshot.png
  22. Member
    Dec 2021
    Polska
    MPD:
    Unfortunately, it didn't work, how do I check the license URL? I did not find another one in developer tools. After opening https://b2c-www.redefine.pl/rpc/drm/ is "500 Internal Server Error Server got itself in trouble"
  23. Originally Posted by noikz View Post
    That means your headers are wrong.
    CTV normally only gives 2 keys. I believe video is first key and audio is second key.
    I don't know why but if you don't have this in:
    headers = {
        'authority': 'license.9c9media.ca',
        'sec-ch-ua': '" Not A;Brand";v="99", "Chromium";v="96", "Google Chrome";v="96"',
        'sec-ch-ua-mobile': '?0',
        'user-agent': 'Mozilla/5.0 (Windows NT 10.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.7113.93 Safari/537.36',
        'sec-ch-ua-platform': '"Windows"',
        'accept': '*/*',
        'origin': 'https://www.ctv.ca',
        'sec-fetch-site': 'cross-site',
        'sec-fetch-mode': 'cors',
        'sec-fetch-dest': 'empty',
        'referer': 'https://www.ctv.ca/',
        'accept-language': 'en-US,en;q=0.9',
    The server will throw you 3 random junk keys.
  24. Also, in general terms, maybe not specific to this above ^^
    with 'accept-language': don't invent options you would like to have - give wks-keys (or ghost's online tool) the only language options that are returned from the lic request.
  25. Originally Posted by RedPenguin View Post
    Thanks for this, working perfectly now.
  26. Hi, does anyone know if http://getwvkeys.herokuapp.com/ supports headers with Bearer tokens in them?
    For example
    accept: */*
    authorization: Bearer st2.s.AcbH5vBpuw.jtykAAtHRwUecQeFvobDljRnGh2Bcu5S_R0mYX2pJhCv0y8SnWH9Z1G15zmxRundKP9LKHLCvtvFJGRPHW2X0PF1uQVLS9AJGQwZPyIcfIM.Ax_mYl94yt11aqtcxAgI9lqiF1GCx4FumwEoNNTLCBevbUwx9kD2dbHikShrZsmoxwTGB_ES2W8-7x9LJz8Jjg.sc3
    content-length: 104
    content-type: application/json; charset=UTF-8
    I've gotten the site to give me keys for other videos but this is the first video i encounter with bear auths in the header and I cant seem to get it to work, thank you!
  27. Member
    Jan 2022
    sweden
    would you please help :
    licence : https://ott.cytavision.com.cy/VSP/V3/ExternalDRMLicense?src=https://cyta.live.ott.irde...contentId=1018
    Pssh : AAAAPXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAB0IARIQ3A fL+s2yRECJ9077GKYZkSIEMTAxODiQHA==
    Accept-Encoding: gzip, deflate, br
    Accept-Language: fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7
    AcquireLicense.CustomData: eyJraWQiOiJlODViNTI2YS1mMTkzLTRjMjItODc1Mi0yOGZjNz czYjdiYmEiLCJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.eyJ zdWIiOiIzMTkyNzE0MiIsImVwbyI6eyJtdmkiOjAsImhkYyI6I m5vdFJlcXVpcmVkIiwiY2dtIjozLCJsZXQiOjE2NDQ0NjQzODI sInBlciI6dHJ1ZSwibHN0IjoxNjA0MzgzMjQ0LCJzbGUiOjB9L CJpc3MiOiJWU1AiLCJlbnQiOlt7ImVwaWQiOiJkZWZhdWx0Iiw iYmlkIjoiMTAxOCJ9XSwiZXhwIjoxNjQxODYxODA5LCJhaWQiO iJjeXRhIiwiaWF0IjoxNjQxODYxNjg5LCJqdGkiOiIzNWM2YTV mZi0yOGQxLTQ3YzMtYWJmYS03ZWQ5NWZhYjgwOWMifQ.k3DgEN nbnXqzyaVICpiYFH20jCFwvofWLcbzjgr90J2g1MMUMiHukNzp vLaedlaRgBrq3TnaaJyWZCVRdd9nVFOza-9sapuHyl2gtbCFEUdLPx8qNoOutkowXhjWfmwVLCcrC3G8JM9T X4-N0v38nUK1qLMU6yS3EVoRL_GmfMY51OCH0HZC9RzoOUyL7Zp3F ywrzIdWp8IsklXoHmNbvkPwNqS_mHsNm2nvx-oU-B0N5mHCHDBV8S0Iev4Vn7NCaxKHAzIUerJj3gr8-6ch62oUAxMckISxs6tdpYpme7Tl4YxiF-QqR3hjBlWYPivkSidCqX38JdyGEcK4Hii_dA
    CADeviceType: Widevine OTT Client
    Connection: keep-alive
    Content-Length: "2"
    Cookie: _ga=GA1.3.1576976174.1632073434; _gid=GA1.3.138077158.1641686319; CSESSIONID=45DD687DD10EB522BE4911AAFBD7F9F9; XSESSIONID=0359T7SCBWPSBNSSB6909B0SK5N4MXIN; CSRFSESSION=9a32483498a4fce9133dc2eaef488c6512b639 55a3aa642c; JSESSIONID=0359T7SCBWPSBNSSB6909B0SK5N4MXIN; _gat_gtag_UA_39625407_18=1
    Host: ott.cytavision.com.cy
    Origin: https://ott.cytavision.com.cy
    Referer: https://ott.cytavision.com.cy/EPG/WEBTV/index.html
    User-Agent: Mozilla/5.0 (Windows NT 6.3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36
    but always error : ERROR
    ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
    what's wrong with ? i doubt it is geo-lock , or license not correct .
    any help please
    thank u .
  28. psaframe
    Mar 2021
    Algeria
    For example
    accept: */*
    content-length: 104
    Ghost D'ont work with starzplay.
    license request needs extra json exchange to get keys
  29. Originally Posted by naim2007 View Post
    For example
    accept: */*
    content-length: 104
    Roger that! Thank you!
