Closed Thread
Page 39 of 66
FirstFirst ... 29 37 38 39 40 41 49 ... LastLast
Results 1,141 to 1,170 of 1969
  1. I Have Started a new Thread to discuss Dumping L1 & L3 CDMS only: https://forum.videohelp.com/threads/404219-How-To-Dump-L3-CDM-From-Android-Device-s-%2...29#post2642515, we will only talk about Dumping L1 CDM's Privately and L3 CDM's Only, NO BULLYING ALLOWED ON MY THREAD Please and Only Discuss L1 & L3 CDM's Only
  2. Originally Posted by EatThis View Post
    Yeah, I don't think you know what you're talking about, why don't you research what VMP means and what it is for? While you are at it, why don't you just do that, setup a proxy and intercept network traffic to the Amazon Prime app specially when doing license request instead of speculating.
    Yea, I read up on VMP, but thanks.
    If you have insights to share, then please do. If you just have snarky comments, then keep them to yourself please.
  3. Originally Posted by lomero View Post
    Originally Posted by filipino View Post
    what else does dumper do?
    this only. but this is a great tool
    I'm thankful, but wks has only worked for me with a couple of pages
  4. Originally Posted by Dannyboi View Post
    Anything leaked is usually out of date and often needs knowlege on what changes need to be made to fix them. And yeah any leaked L1 is likely to die super fast
  5. i received cdm l3 key without any android device
    just use virtualbox and android-tv iso lol
  6. Originally Posted by darkw4v3 View Post
    When I say this some may think I am talking rubbish but this is based on my own findings. On mutiltple Android devices I've noticed Amazon Prime just don't interact with the included L3 CDM when it's L1 has been revoked or the device does not have one. It appears to just use PlayReady, the Amazon Prime app probably have included binaries or code that allow it to use this DRM instead. This is not unsual because most Android devices are not manufactured with any PlayReady support or code but despite clearly stating on the license request body or response that is using PlayReady and an obvious data that is not found on a Widevine license request/response.
    - It's content cannot be parsed with Google photobuf.
    - Android logs does not show the CDM being intialized.
    - An erased device to factory default and only installed the Amazon Prime app without the Google Play does not even contact Google to provision the L3 CDM certificate and PK.
    - if you inspect the traffic from the Amazon Prime app for Windows 10, which for obvious reasons would use PlayReady, it has the same license request structure.
    Furthermore, the Amazon Music app does not use it either. It used an specific CDM that appears to be specially made for the Music app.
    It could be the fact that all devices tested are rooted? Maybe, but until I find evidence it does use the L3 CDM included in the Android device and the fact all Android L3 license requests always fails, this seems like a more reasonable conclusion. Besides from Amazon point of view this makes sense, it's a software variant of the PlayReady DRM, possibly exposed to be broken anyway but is less exposed than Widevine L3.
    You can always test and continue experimenting for the rest of us, but when it gets revoked and eventually stops working with the rest of the websites. You will know why.
  7. Roge idiots like this are the reason why you should always keep your CDM private. Is no longer the reseller or the one that overshare it. But that one that is butthurt because can't learn how to use it and wants to ruin it for others. No real compelling reason to share one if you have one you've obtained yourself.
  8. Originally Posted by EatThis View Post
    I don't even know why anybody would share their own private CDM.
    I only have L3s from my devices but I do have an L1 Device, but I know it's not easy to dump from it.
    I know if I somehow did actually dump it, I'd have to keep it on a flash drive and lock it in a safe. I can't be sharing that, it's like having an extremely rare baseball card or something.
  9. Originally Posted by EatThis View Post
    That's interesting. It's somewhat different that what I observed this afternoon on my android device. At least once, the AP app hit the same GetPlaybackResources endpoint that the browser based playback does - and it requested a WV license - without VMP. However, I couldn't reproduce that. None of the later attempts hit that endpoint. Moreover, when I hit that endpoint with the exact same headers and request, it is denied. So, not really sure why, but I don't really care at this point. Amzn doesn't have any content that I care about that can't be viewed elsewhere. Screw them.
    Update: It looks like the one GetPlaybackResources hit came from Chrome, from a tab I had left open. This makes more sense, so your analysis is probably correct.
  10. Originally Posted by RedPenguin View Post
    Exactly.
  11. Originally Posted by darkw4v3 View Post
    I think you may be confusing VMP with privacy mode. In Privacy Mode enabled the device information of the device get encrypted with the service certificate public key, so that only the streaming service can see it. Is is used on L1 devices and Google Chrome for obvious reasons, part of Chrome license request preparation when using privacy mode vmp goes into this preparation. Android devices will L3 do not use privacy mode and generally is just a license request. As ive mentioned vmp is only used on Chrome, Amazon may even allow a license request without using it in a Chrome CDM but will be limited to SD keys.
    And that is what I 100% agree Amazon hardly has anything interesting, if there is, other places already make the content available anyway.
  12. I am curious if the poster of that "new GH repo" has this figured out. I haven't been able to decompile the pyc files back to source. They're using an obfuscation I haven't been able to identify yet. There is a license request module or class defined specifically for AP, so it has me curious. But also me: screw them. haha
  13. Originally Posted by darkw4v3 View Post
    Yeah, lack of interesting content really does not motivate enough to bother with it.
  14. Originally Posted by RedPenguin View Post
    He leaked it because it was already leaked and blacklisted on some services.
    But now it's partially revoked.
    discord=notaghost9997
  15. Originally Posted by lazyman View Post
    Interesting. I'll try this after New Year when I have more time on my hands.
    Anyone else cares to try this, or elaborate more and say if it's successful?
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  16. Originally Posted by [ss]vegeta View Post
    I'll give it a try. Where did the ISO come from?
  17. Originally Posted by crusr4 View Post
    I don't know, but prolly the first Google result from XDA with a link to Mega will suffice.
    click click2
  18. Originally Posted by [ss]vegeta View Post
    Yeah, that was the one I was going to try. Just wanted to check if there was a specific one I should get.
    Dec 2021
    Tunisia
    any one can share L3 CDM with me
    i will keep it safe, no public
    i need it only for shahid.net
    Oct 2021
    Poland
    Hello, can anyone help me with this? I added the headers to headers.py file:
  21. Originally Posted by PanMarSag View Post
    Open l3.py and put ### on the lines that I have put ###.
    Don't get confused by the three ### because I commented out like that just so I can differentiate between what I commented out, and was commented out before me, in case I broke something.
    [Attachment 62594 - Click to enlarge]
    Also, when lic.drmtoday is used for license URL, you have to add ?specConform=true at the end.
    click click2
  22. Member
    Oct 2021
    Poland
    Now when i execute l3.py this appears:
    Here's the headers.py file:
  23. Originally Posted by PanMarSag View Post
    Eh, probably the code needs more editing because of json data.
    Or maybe you can try getting the WHOLE headers result from curlconverter.com
    click click2
  24. Member
    Oct 2021
    Poland
    But in which language do i convert from the curl? I converted curl to Python and it's the same.
  25. Originally Posted by PanMarSag View Post
    Python.
    Anyway, I just tried with "my" version of Pywidevine and I was successful at getting keys from my local HBO go.
    Widevine_keys also succeded.
    Input MPD URL: https://akamaicdn.hbogo.eu/d8f40cb8-efa8-5f23-7214-5f3f073a5cc1_m116992_hbo/COMP/139161193_adr_comp_0cc2c364-5dba-4f1c-96f9-5640f98f5bbb_3400000_v2.ism/manifest
    License URL: https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
    Unable to find PSSH in MPD: 'MPD'.
    Edit getPSSH.py or enter PSSH manually: AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEK+fQshJD8DFvrmDgCWpJwY=
    PSSH obtained.
    license response status: <Response [200]>
    KID:KEY -> af9f42c8490fc0c5beb9838025a92706:08eb62fea9f18c2ea35ef3d5ea497e67
    Contact me on Discord and give me access to your local HBO. I would really like to see if I can get keys without editing anything.
    click click2
  26. I tried drm dumper with my redmi phone(Android 9 rooted). Unluckily, I got only keyboxes dumped. DRM info showed L3 OEM API 13 ,can anyone help me to get the private key ? thanks.
  27. ...
  28. Originally Posted by PanMarSag View Post
    If you are using this version https://github.com/medvm/widevine_keys
    in headers.py,
    Paste the converted curl
    After paste this,
    # params inserted below will be passed to data-raw
    token = 'PFYtFSqWMYIROJYywBp0rbKvpD3z6N6E6UezNrZmCeKHkcJ5B iH4J8qwO0kfWOmrSsyFJMg9OqKKEwvuQiXL4qdDTa6ZYplNV9I Qt6eEuveglDxjVlYd0vAecS5TZKn5mIs01YxcYNlTC7tu3BIk6 3JhMykMWEMmj1oEqaLa7N3ZrfU2VTlEPaWXBQV6PxnFeD022Yi 298GOX/lDik7sXt5u4duT0aKIYbz0HPmjoh8b9Uy8bvzJUa0/SlgRcsW8RNTNjRJHM6N7BESCBGFEZcWoSXeDLEblEfRoBKro2i DGB1neLfRdY1fj7tJX1Rn9lj+OJwRTrBV4XoTQFuSsFwvYCeQf kAoRHXnze9njI5pY7sYgIGxuM4Zh3Wqaps6kxdO53QMm0jJ/L41X6r5CikSGKQ3Rcps8eQccZb9svEuyXMof2nm+eYL+AVPPrf mAf/BrmUHfiuF9CmNsF9pI7PjJfLeASmh3KDI/5gUuC4uJB7rjTzHVWNRz8MSvYjJ37/5V9+FTihpu04+0jFZ1AlGRks2dzk2IGvm5WcwUhsW2l/oQXlh7AgsksIl2DT0wH11WeG+h1/ijymMcG9AZzsxtkC53eLJ8bl55/Aag0TJfX4N6KvV7UhglXxkLifb06bLK/wlcGCfb01b4cnngcjPJEMxh2+Q7sJSnbyrtsfodzNah8JXITmx 5kTkFFZkdtga1ha9jAb+Z40VMQfbrCLgh0GEe2G3VczcIt8QHA WAeS91TkzLbMRAugbgLvdbI8yQXtM15uo+TXrV4PNFprug33An vnQu7IpNxlmgPMZhEn4Qqc/V++OFIpz/JYEMnLFvjYcXE2+sPc4uKnoE0xk33+IgZKtWtDhxRg2SJKyKOY xXucXybUuqPP/d+Nq1VNhD84Of+EfVvBjs1u75pNz/kmu5ms9ppRMkafq0/2311hbYi6VXmp6AeJweGJWkGKEFxw7xADuC8iM7xWnXW5aiNvh bsXBOwuTK8b2ioxjrg6OFhiMck+z9M5FHg+ktY7YB8iY+0V6B/Op2cQGtLaZ2E9lsomlQpxL+LiPI7UWEqmALEGH/Pk5tdLnlFRjEk2PPc8YURw+/nkP9tqJ/AXQwaXc9iwC5yxlYPCsp/Tc4='
    provider = 'kakaotv'
    releasePid = "_qVpiY31v_oU"
    As an example headers.py must be like this
    headers = {
    'authority': 'license.pallycon.com',
    'pallycon-customdata-v2': 'eyJkcm1fdHlwZSI6IldpZGV2aW5lIiwic2l0ZV9pZCI6IklOS 0EiLCJ1c2VyX2lkIjoicHR6NGMwNmgiLCJjaWQiOiJiaWdidWN rYnVubnkiLCJwb2xpY3kiOiIwNDV5ejUvK3BKbGpBWXRWYWpXZ jlWd2c1MTFHekdtcTUrV1V4Y29JOHg4OHhkWHdFQnNvQW1HZHV oWkF6UXU2ZDQ4M3dpaXJOS0tVOWtpenRDRmRnUT09IiwicmVzc G9uc2VfZm9ybWF0Ijoib3JpZ2luYWwiLCJ0aW1lc3RhbXAiOiI yMDIxLTEyLTI3VDEwOjU4OjU5WiIsImhhc2giOiJKOFBOTFVoY UdsRTNTdXpaY3laM3BVUzJFYkJxSEI1WGR2dVhhK0xyNDBzPSI sImtleV9yb3RhdGlvbiI6ZmFsc2V9',
    'sec-ch-ua-mobile': '?0',
    'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.54 Safari/537.36',
    'sec-ch-ua-platform': '"Windows"',
    'sec-ch-ua': '"Google Chrome";v="95", "Chromium";v="95", ";Not A Brand";v="99"',
    'accept': '*/*',
    'origin': 'https://sample.pallycon.com',
    'sec-fetch-site': 'same-site',
    'sec-fetch-mode': 'cors',
    'sec-fetch-dest': 'empty',
    'referer': 'https://sample.pallycon.com/',
    'accept-language': 'en-US,en-GB;q=0.9,en;q=0.8',
