Closed Thread
Page 33 of 66
FirstFirst ... 23 31 32 33 34 35 43 ... LastLast
Results 961 to 990 of 1969
  1. Originally Posted by Loryanam2 View Post
    Originally Posted by T33V33 View Post
    Just out of interest... What are people expecting to find when they get an invite?
    Help ,instructions and tutorials etc
    Then you may be disappointed... This forum has probably been the most helpful. A couple of other places (usually support for various apps) looked like they were going to be helpful, but have just turned into places for people begging for someone else to spoon feed them and as a result it often ends in a ban on the discussion there.
    Any of the more 'in the know' developers keep their cards close to their chests. They're very reluctant to share their personal scripts. The best most of us can hope for is the likes of the already leaked tools, many of which are old and no longer work (without knowing how to edit them). WKS-KEYS is probably the main one that still works... but even that needs personal variations to the script (or completely new scripts) for various sites to work. Sadly the instructions that came with that are about as good as it gets.
    Tutorials are pretty much non-existant too. I have seen various people ask for help elsewhere and often the answers that come back make no sense unless you know Py etc. In fact serveral times I have seen them literally just say 'go learn Python'.
  2. Originally Posted by Loryanam2 View Post
    Exactly, good answer.
  3. ..
  4. Hello,
    I managed to dump the wvdumper data and it works perfectly, how long does it work?
    I used a redmi 3s, pixelExperience Android 11 rom, L3 DCM 15.
  5. Originally Posted by ga2p View Post
    Hello,
    It works until it gets blacklisted/revoked. Since it's your personal one, don't share it and it will maybe last much much longer (maybe years). Anything shared is likely to stop working quicker.
  6. It works until it gets blacklisted/revoked. Since it's your personal one, don't share it and it will maybe last much much longer (maybe years). Anything shared is likely to stop working quicker.
    does sharing your device model also make it possible to get revoked?
  7. Is the key different for each device? Is it the same for the same model?
  8. Originally Posted by kijubi555 View Post
    Each device has an individual key (different deviceIDs)... if they revoke your deviceID then the CDM you extracted and the device you extracted from will no longer be able to decrypt Widevine.
    Then there is the SystemID... Google could revoke that too... but that would stop all (millions of) devices using that SystemID from being able to decrypt Widevine unless they roll out an OS update with a new SystemID to affected devices. Which is only any good for devices still supported with new updates.
  9. Originally Posted by T33V33 View Post
    and if the rom is changed, will it be useless?
  10. And when it is blocked, can you do the same process again to obtain it or is it blocked forever since it is from the device?
  11. --
  12. Originally Posted by ga2p View Post
    if it blocked the device that you extracted it from will never be able to play any widevine video again
    so if your key is revoked by google you need to buy a new device to even play any widevine video again
  13. Originally Posted by ga2p View Post
    locked forever
    Dec 2021
    Spain
    It has no reason to get blocked unless you share it or it gets abused maybe e.g mass downloading many items quickly.
    Or your device goes eol. Or the cdm gets revoked but I'd cdm is revoked you could update Android version on device probably and dump keys again.
  15. And changing the rom or resetting the device? It was to help the one who needs it
  16. Originally Posted by kenyard View Post
    How often is it recommended to download?
  17. Originally Posted by romanok View Post
    Once every two days, preferably at around 13:37 GMT
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  18. Originally Posted by ga2p View Post
    the device is also blocked for ever yes for ever so if you extracted the key from a new device you bought it recently Do not use it even for yourself
    try on an old device you don't want it anymore
  19. Originally Posted by [ss]vegeta View Post
    I'm talking about downloading a series of 40 chapters for example, how often should I download a chapter?
  20. hello how can i run a py file with cmd and not have to type whenever i open it?
  21. Or buy a cheap Android TV box from Amazon, extract the key and then return it
  22. Originally Posted by romanok View Post
    Drag and drop?
  23. Originally Posted by T33V33 View Post
    What model you recommend? Can recommend something that will come pre rooted!
  24. Also its christmas here. So merry christmas y'all!
  25. Originally Posted by myteryuser View Post
    T95 S1. Android 7.1. Pre rooted. Frida server from Play Store, ADB wia WiFi
  26. [QUOTE=T33V33;2642047]
    Google used to do this but not any more, thankfully. Either way you don't want to be rooting your personal phone, but instead get a cheap throwaway random Chinese model from alibaba or second hand one pref android v7 or 8.
  27. Originally Posted by romanok View Post
    Make a .bat file, with python xxx.py. Change xxx with the name of your .py file.
  28. Originally Posted by oknchm View Post
  29. Originally Posted by T33V33 View Post
    Does it work for sure? Have you tried it
  30. Originally Posted by myteryuser View Post
    Yes
