Hi, @[ss]vegeta, The other day I pmed you about that edit. Then I wasn't able to go past hooks but now I have manged to go to the keyboxes. Can you please pm me the edit on what should I do now because your Pm is blocked. I am on android 7 this time! I am now freaked out because that lenovo is revoked. I really need it please help me bro.
Closed Thread
Results 901 to 930 of 1969
AnonymousGuest
To get the pcok keys you have to generate the correct signature header every request.
To generate the signature you have to get the correct data and the correct hmac key, the data is them hashed in hmac-sha1 with the correct key and then base64 encoded.
Mates,
every time i run wvdumper , i am receiving the below error
Failed to load the Frida native extension: DLL load failed while importing _frida: The specified module could not be found.
Please ensure that the extension was compiled for Python 3.x.
File "C:\Users\Administrator\Desktop\dumper-main\dump_keys.py", line 4, in <module>
import frida
File "D:\Python_install\lib\site-packages\frida\__init__.py", line 24, in <module>
raise ex
File "D:\Python_install\lib\site-packages\frida\__init__.py", line 7, in <module>
import _frida
ImportError: DLL load failed while importing _frida: The specified module could not be found.
i have tried 3 different versions of python, however the use remains the same.
would please give me any hint so i can fix this?
thanks
What is your main/default python version?
Use 3.9 to lower and make sure to uninstall previous installed on other py version
Then if your main is py 3.10
you should run "py -3.9 dump_keys.py" if you installed frida on 3.9
Looks like your error also when you execute "frida-ps -U"?
that above should fix your problem
thanks mate..
yeah i am running Py 3.10.1
and i have installed 3.8 by using py -3.8 dump_keys.py and seems to be working now
but i have got another error :
File "dump_keys.py", line 14, in <module>
device = frida.get_usb_device()
File "D:\p3.8\lib\site-packages\frida\__init__.py", line 89, in get_usb_device
return get_device_matching(lambda d: d.type == 'usb', timeout, **kwargs)
File "D:\p3.8\lib\site-packages\frida\__init__.py", line 97, in get_device_matching
return get_device_manager().get_device_matching(predicate , timeout, **kwargs)
File "D:\p3.8\lib\site-packages\frida\core.py", line 26, in wrapper
return f(*args, **kwargs)
File "D:\p3.8\lib\site-packages\frida\core.py", line 58, in get_device_matching
return Device(self._impl.get_device_matching(lambda d: predicate(Device(d)), raw_timeout))
frida.InvalidArgumentError: device not found
currently i have installed magisk frida module (which should run server on boot)
i am not sure what am i missing exactly
There are people in underground pages offering L3 CDM for €100. That's too expensive. Not to mention the extremely high risk of scam.
The public tool, Anystream, charges €110 but that's not a full-fledged CDM, instead the tool supports just a handful of streaming platforms.
The standard seems to be €100 for an L3 CDM. That motivates me to try this dump method. Worst part would be probably rooting my phone. I'm not in the mood to backup everything right now...
[QUOTE=liongtwap;2641592]I make some modified to l3.py in WKS-Keys to make easier for you all. Make sure you already backup l3.py
1. make output file (txt file) so the result will not gone. This output file in the same folder with l3.py
Just copy and paste to the most bottom in l3.py (starting line 31 from original l3.py using Notepad++)
hi please could you send me the modified file or a screenshot of how it should look like, I tried and I was unsuccessful.Code:f=open("output.txt","a+") f.write('PSSH = ' + pssh + "\n") f.write('License URL = '+ lic_url + "\n") f.write('--KID:KEY '+ key + "\n\n")
@naim2007 you wrote
You have something against the publicly sharing of knowledge. Do you believe that knowledge should be hidden? Is there some insecurity that you have that the sharing of knowledge will diminish and not enhance the amount you have? Tell me, when should we expect the return of bonfire of the vanities.No more discuss methods & drm & dumps & even keys in public.
It's good idea to create private server like discord and chat staff like this.
Strip Playready and Widevine DRM
By freaknik in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jun 2024, 16:20 -
Decoding manifest.mpd (Widevine)
By WaitForIt in forum Video Streaming DownloadingReplies: 6Last Post: 7th Jun 2021, 14:44 -
getting widevine CEK key
By netbreak in forum Video Streaming DownloadingReplies: 1Last Post: 19th Feb 2018, 13:03 -
Looking for anyone with Google Widevine knowledge.
By cookeri6 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2017, 14:33 -
By cookeri6 in forum Video Streaming DownloadingReplies: 0Last Post: 15th May 2017, 13:45
