run cmd as administratorCode:E:\WKS-KEYS>pip install pycryptodome Requirement already satisfied: pycryptodome in c:\users\pc\appdata\local\programs\python\python310\lib\site-packages (3.12.0) E:\WKS-KEYS>pip install pycryptodomex Requirement already satisfied: pycryptodomex in c:\users\pc\appdata\local\programs\python\python310\lib\site-packages (3.12.0) E:\WKS-KEYS>py l3.py Traceback (most recent call last): File "E:\WKS-KEYS\l3.py", line 2, in <module> from pywidevine.L3.cdm import cdm, deviceconfig File "E:\WKS-KEYS\pywidevine\L3\cdm\cdm.py", line 15, in <module> from Cryptodome.Cipher import PKCS1_OAEP, AES File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\Cipher\__init__.py", line 36, in <module> from Cryptodome.Cipher._mode_gcm import _create_gcm_cipher File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\Cipher\_mode_gcm.py", line 51, in <module> from Cryptodome.Util import _cpu_features File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\Util\_cpu_features.py", line 34, in <module> _raw_cpuid_lib = load_pycryptodome_raw_lib("Cryptodome.Util._cpuid_c", File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\Util\_raw_api.py", line 309, in load_pycryptodome_raw_lib raise OSError("Cannot load native module '%s': %s" % (name, ", ".join(attempts))) OSError: Cannot load native module 'Cryptodome.Util._cpuid_c': Not found '_cpuid_c.cp310-win_amd64.pyd', Not found '_cpuid_c.pyd'
Closed Thread
Results 751 to 780 of 1969
E:\WKS-KEYS>pip install pycryptodome-test-vectors Requirement already satisfied: pycryptodome-test-vectors in c:\users\pc\appdata\local\programs\python\python310\lib\site-packages (1.0.4) E:\WKS-KEYS>python -m Cryptodome.SelfTest Traceback (most recent call last): File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\runpy.py", line 196, in _run_module_as_main return _run_code(code, main_globals, None, File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\runpy.py", line 86, in _run_code exec(code, run_globals) File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\SelfTest\__main__.py", line 38, in <module> SelfTest.run(stream=sys.stdout, verbosity=1, config=config) File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\SelfTest\__init__.py", line 61, in run tests = get_tests(config=config) File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\SelfTest\__init__.py", line 82, in get_tests from Cryptodome.SelfTest import Cipher; tests += Cipher.get_tests(config=config) File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\SelfTest\Cipher\__init__.py", line 31, in get_tests from Cryptodome.SelfTest.Cipher import test_AES; tests += test_AES.get_tests(config=config) File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\SelfTest\Cipher\test_AES.py", line 31, in <module> from Cryptodome.Cipher import AES File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\Cipher\__init__.py", line 36, in <module> from Cryptodome.Cipher._mode_gcm import _create_gcm_cipher File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\Cipher\_mode_gcm.py", line 51, in <module> from Cryptodome.Util import _cpu_features File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\Util\_cpu_features.py", line 34, in <module> _raw_cpuid_lib = load_pycryptodome_raw_lib("Cryptodome.Util._cpuid_c", File "C:\Users\PC\AppData\Local\Programs\Python\Python310\lib\site-packages\Cryptodome\Util\_raw_api.py", line 309, in load_pycryptodome_raw_lib raise OSError("Cannot load native module '%s': %s" % (name, ", ".join(attempts))) OSError: Cannot load native module 'Cryptodome.Util._cpuid_c': Not found '_cpuid_c.cp310-win_amd64.pyd', Not found '_cpuid_c.pyd'
E:\WKS-KEYS>pip install -U pycryptodome Requirement already satisfied: pycryptodome in c:\users\pc\appdata\local\programs\python\python310\lib\site-packages (3.12.0) E:\WKS-KEYS>pip install -U pycryptodomex Requirement already satisfied: pycryptodomex in c:\users\pc\appdata\local\programs\python\python310\lib\site-packages (3.12.0)
similar problem OSError: Cannot load native module
https://github.com/Legrandin/pycryptodome/issues/155
Can you actually locate the file via Windows explorer? In the error it's mentioned that it cannot be found.
So, you are searching for
Code:_cpuid_c.pyd
Code:C:\Users\pc\AppData\Local\Programs\Python\Python310\Lib\site-packages\Crypto\Util\
Code:C:\Users\pc\AppData\Local\Programs\Python\Python310\Lib\site-packages\Cryptodome\Util\
I think I figured out the problem with wvdumper only dumping keyboxes (not to be confused with the problem of stuck at "hooks completed").
I might help you. Message me via private message.
Three prerequisites:- Android needs to be 7-9
- Download the app "drm info" from play store and check if OEM Crypto is 13 or less
- You have to know what's adb and some of its basic commands
@nimdinu you wrote
when run wks keys script it shows key and close window instantly... i can't see key..
Maybe make a high speed screen capture of the display maybe 10000 frames per second and playback at normal speed.
On second thought, why don't you study the script and fix the problem.
Every one wants key, keys and more keys. No one wants to read, read and more read.
Where is "I think, therefore I am a hamster" when you need him? I know his handle was not René or Descartes
@[ss]vegeta
Two prerequisites:
Download the app "drm info" from play store and send screenshot of the "Widevine CDM" part
You have to know what's adb and some of it's basic commands
I think you just bit off more that you can chew.
You will be answering private messages from now till doomsday.
Have fun
I found that, to try : https://github.com/wvdumper/dumper
hi can someone help me after this poster nothing happens
[Attachment 62433 - Click to enlarge]
It can be both.
From my experience, all popular apps will give the same blob and private key.
However, playing from inside the Chrome browser on the phone will give you a different blob and private on different sites. Also different from the apps. Now think about that...
Hulu lets you play directly in Chrome, Discovery+ didn't let me.
You can also play in Chrome
https://www.vdocipher.com/
https://bitmovin.com/demos/drm
Well I don't have much experience but I also read and experienced that Samsung is a bad choice.
I succeeded on a Xiaomi Redmi Note 5 AI 2017.
7-9 Android is best, OEM Crypto API should be 13 or less (this can be seen in app Drm info).Last edited by [ss]vegeta; 18th Dec 2021 at 16:40.
Strip Playready and Widevine DRM
By freaknik in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jun 2024, 15:20 -
Decoding manifest.mpd (Widevine)
By WaitForIt in forum Video Streaming DownloadingReplies: 6Last Post: 7th Jun 2021, 13:44 -
getting widevine CEK key
By netbreak in forum Video Streaming DownloadingReplies: 1Last Post: 19th Feb 2018, 12:03 -
Looking for anyone with Google Widevine knowledge.
By cookeri6 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2017, 13:33 -
By cookeri6 in forum Video Streaming DownloadingReplies: 0Last Post: 15th May 2017, 12:45
