Someone will come to the rescue after the 6th hopefully - and I think I know who......
Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
Closed Thread
Results 271 to 300 of 1970
Here's an example of mymovies license URL:
HTML Code:https://wv.service.expressplay.com/hms/wv/rights/?ExpressPlayToken=BQAiqQLiKbEAJGVhMWI4MzIyLTE0NGYtNGI5My1hYzRmLTE0NDg1YjEzOTE5YQAAAGCwpXNJE4M4GZEZsnkI-aL7vyoKIhm8a093Hcz3wvaYm-NPLywy9fC4yboBANH3LrVRluZGsOnOoc7OsoHKOAI3cK8BJ2-0m32YYnOyA5eH5ywwr5EXNmPvRvODTrD7RzRBXRi-624R_-zLvhYcjby8g-0ENg
I want to get the keys from this site
I've tried locating many license urls and it doesn't seem to work either.
(Other sites with only 1-2 keys work fine, I remember this one has 5 keys)
SITE:https://tv.kakao.com/channel/3883265/cliplink/424354831?metaObjectType=Channel (EP.12)
vpn:Korea
Please help to get this website method
Thank you in advance.
[Attachment 62144 - Click to enlarge]
Before you play the video, you should open developer tools in Chrome (right click anywhere on web page, choose inspect).
Then go to the network tab. Then play the video. Then in the textbox you should write widevine, or cert, or auth, or license or drm and something like this will pop up.
To make sure you are on the correct thing, you check if the payload on the right shows "garbage" like this.
Then, you go Headers next to Payload and you copy the Request headers.
Thx so much for ur hardworking notaghost!
I didn't want to pm u as you are for sure busy, so plss can you add vdocipher support in your website?
I've asked Vegeta before about this and he said he cannot get keys from vdocipher and he told me to wait until the Guesser stops working and talk to u again!
My reasons to download those educational videos because some of them are time limited and other is restricted by number of watching times, and in future I will sure need to rewatch my lectures if I forgot something or I need to revise something!
Ps. All of those videos are using vdocipher so that's why I really need you to add support of vdocipher.
Thx a lot!
Can you elaborate more? Which site doesn't get you keys?
"Revoked by google cdm" doesn't make much sense.
Notaghost's decryptor works on most sites, if the license request and response is "normal" like most of the sites use.
There are some sites that give license response in a different way, and the version of Pywidevine that is used in notaghost's decryptor cannot handle those.
The decryptor uses an Android general CDM that is not revoked on many sites, but maybe the site you are trying revoked it.
so far I have gotten a key with this web, maybe someone has the same problem and have solved it
I have this: "Error: PSSH ERROR unable to parse init data"
Code:Proxy {} headers Connection "keep-alive" user-agent "Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.114 Safari/537.36" keys "Error:PSSH ERROR unable to parse init data" license "https://mds.ccp.xcal.tv/license" pssh "AAAIE3Bzc2gAAAAAr7y1Dr90PRO+jxOTDHg5YgAAB/NleUo0TlhRalV6STFOaUk2SWxsU1MxSkJaRmxRVjBRMlQyNXpTRnBDV0UwMFQwb3RURWxUWDA1TGNUZ3hSbGg2V0RjdFpUZFBjV2NpTENKaGJHY2lPaUpTVXpJMU5pSjkuZXlKamEyMU5aWFJoWkdGMFlTSTZJbEZxUTBOQlZsbE5RVlJKV0VSVVNYaE5WRWwzVGtSRk1VNUVhM2hQVm05TlFWUlJSVVZNV1VORlN6QkVVVzFDYmkwNE5ESlNWM1pzZVMxQlRVRlVWVVZHUzJ4bVoxVldXa1IxT1hrd1R6WlplazR6UnpRMWVsOWlUeTFxUkVGRk1rSkpTSEJOU1VodFJFRndhbUV5TURaalJ6bHpZVmRPTlVSQ1JtcGlNakZxV1ZoT01FeFhUbXhpYlUxMFpFaGFjR05uZDAxWk1uUjBUMjVDZG1KSGJHcGxWV3hyUkVKR2FtSXlNV3BaV0U0d1RGZE9iR0p0VFhSa1NGcHdZMmQzUzFreU9YVmtSMVoxWkVSd2NGcEJkMjVrYW1NMFRWUlplVTlFU1RGUFZHTTFUbFJCTVUxNlVYcE9SRVp6VFdwQmQwNXFSVE5PZWxsNFRXcEJNRTFVUlhkTlJFbDRSRUZzYTJOdE1EWmhNbFkxVTFkUlRVcEhTWGxPUkZsNFQxUlpkMHhYU21wWmFtTjBUbXBuZDA1cE1EVlBWRkY0VEZSVk0xcHFZekJQVkZWNldUSkdhVTEzZDJGWk1qbDFaRWRXZFdSRWNISmFXR3hGV2xoS2NHUnRSakJoVnpsMVV6SldOVk5YVVUxSmJVNTJZbGRPYUdNelVYUmpSRUY1VEZkT2NtSlRNWGRaTWxaMVdUTlNNbUZZU1hSTlJFRjRURmRPY2xwSGMwMUJWR05OU1cxT2RtSlhUbWhqTTFGMFkwUkJlVXhYVG5KaVV6RjNXVEpXZFZrelVqSmhXRWwwVFVSQmVVeFhNV3RpVjNNaUxDSmtjbTFVZVhCbElqb2lZMlZ1WXlJc0ltUnliVTVoYldVaU9pSmpaVzVqSWl3aVpISnRVSEp2Wm1sc1pTSTZJa05QVFVOQlUxUXRRMFZPUXkxVVZrbFNJaXdpWTI5dWRHVnVkRlI1Y0dVaU9pSjBkbWx5SWl3aVkyOXVkR1Z1ZEVOc1lYTnphV1pwWTJGMGFXOXVJam9pZERaU1pXTnZjbVJwYm1jaUxDSmtjbTFMWlhsSlpDSTZJbUl5TkRZeE9UWXdMV0pqWWpjdE5qZ3dOaTA1T1RReExUVTNaamMwT1RVelkyRmlNeUlzSW1OcmJWQnZiR2xqZVNJNklrTlBUVU5CVTFRdFEwVk9ReTFVVmtsU0lpd2lZMjl1ZEdWdWRFbGtJam9pVmpjNE1UWXlPREkxT1RjNU5UQTFNelF6TkRGTU1qQXdOakUzTnpZeE1qQTBNVEV3TURJeElpd2lZMlIyY2pweVpXTnZjbVJwYm1kSmJtWnZVbVZ6ZFd4ME9uSmxZMjl5WkdsdVowbGtJam9pVmpjNE1UWXlPREkxT1RjNU5UQTFNelF6TkRGTU1qQXdOakUzTnpZeE1qQTBNVEV3TURJeElpd2lZMlIyY2pweVpXTnZjbVJwYm1kSmJtWnZVbVZ6ZFd4ME9tRmpZMjkxYm5SSlpDSTZJak15TkRJeU9UYzFOamMzTlRVeE9URTNPRE1pTENKemRISmxZVzFKWkNJNklqZzNOamcyTkRBNE9UVTFORFE0T0RZeE5qTWlMQ0poWTJOdmRXNTBTV1FpT2lJek1qUXlNamszTlRZM056VTFNVGt4Tnpneklpd2lhWE56SWpvaVEwNDlVREF5TURBd01EQXdPVEFzSUU5VlBYVnlianBqYjIxallYTjBPbU5qY0Rwd2Eya3RZM010YVc1ME9tTnJiU3dnVHoxRGIyMWpZWE4wSUVOdmJuWmxjbWRsWkNCUWNtOWtkV04wY3lCTVRFTXNJRXc5VUdocGJHRmtaV3h3YUdsaExDQlRWRDFRUVN3Z1F6MVZVeUlzSW01aVppSTZNVFl6T0RZek1qazFPU3dpYVdGMElqb3hOak00TmpNeU9UVTVMQ0oyWlhKemFXOXVJam9pTVNJc0ltMWxjM05oWjJWVWVYQmxJam9pWTI5dWRHVnVkRTFsZEdGa1lYUmhJaXdpWVhWa0lqb2laR3h6SWl3aWFuUnBJam9pUTJ3dlEzQmlZVTVYY2tKclNpdHdWVUYzWkVWRGR6MDlJbjAuUjNyc3FXTjhMdkZzVVl4ODJCLVA5bF83WWFXQ2ZqR0lLZGluVHFJNVQyRU1uWmxaek1GTGNGV0t3cU92MjJ0emZKR0E2SmRMeElfRVhvQkFPS1BBLWt5d1lLSE51Zzh6SUx1SlNSMXE0bFVpLXd4NVdfNG1ld0l1NVFPRzRVaVlVNjNsd0xMajk4U1dtSjhXcmF3ZU5FY1A5RUJzZ3RxNE9zOU4ydFZTTEZ4R1ZOVGlvMHk1cTBwT2dtN0VhclVUdUU1NzJpWmwtdnRON3lvaVhwRldxeFk1VnBkRjdKV18tejdtUTVuUE51YkNndlBBT0pRbVlZS3ZsOHZ3bWg1Q0lxSWcxQVBwUTl5Y2VEQ21DXzdySVQ3MGZYbjZqb0U5V2ptaVg4YTdSQS1MbW1RVjR3S1ZZallnamFpM0F1Qm12V2l3bWV2d2FzbjdhTlNvWnBtLTh3" time "16:40:36" url "notaghost#9997 - http://getwvkeys.herokuapp.com"
I'm getting "Error:RSA key format is not supported" does that mean that site I'm on isn't supported by https://getwvkeys.herokuapp.com/wv
[Attachment 62155 - Click to enlarge]
[Attachment 62156 - Click to enlarge]
[Attachment 62157 - Click to enlarge]
Code:Proxy {} headers Connection "keep-alive" User-Agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:93.0) Gecko/20100101 Firefox/93.0" keys "Error:" license "https://mds.ccp.xcal.tv/license" pssh "AAAAaHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEgSJDYwN2JiMmMyLWI0ZTAtMzJiZi03NTM3LWQ5ZGIzMmNlNzJmZCIgd1laU1M0Um94WUE4Rjg3NE10UDcyQUlWSmxkN19uQ1I=" time "18:11:46" url "notaghost#9997 - http://getwvkeys.herokuapp.com"
The web that I am trying to decipher gives me these 3 options, I choose the shortest
but i still get error
Code:<cenc:pssh>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</cenc:pssh>
Code:<cenc:pssh>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</cenc:pssh>
Code:<cenc:pssh>AAAAaHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEgSJDYwN2JiMmMyLWI0ZTAtMzJiZi03NTM3LWQ5ZGIzMmNlNzJmZCIgd1laU1M0Um94WUE4Rjg3NE10UDcyQUlWSmxkN19uQ1I=</cenc:pssh>
Code:Proxy {} headers Connection "keep-alive" User-Agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:93.0) Gecko/20100101 Firefox/93.0" keys "Error:" license "https://mds.ccp.xcal.tv/license" pssh "AAAAaHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEgSJDYwN2JiMmMyLWI0ZTAtMzJiZi03NTM3LWQ5ZGIzMmNlNzJmZCIgd1laU1M0Um94WUE4Rjg3NE10UDcyQUlWSmxkN19uQ1I=" time "18:37:28" url "notaghost#9997 - http://getwvkeys.herokuapp.com"
Decoding manifest.mpd (Widevine)
By WaitForIt in forum Video Streaming DownloadingReplies: 6Last Post: 7th Jun 2021, 13:44 -
getting widevine CEK key
By netbreak in forum Video Streaming DownloadingReplies: 1Last Post: 19th Feb 2018, 12:03 -
Strip Playready and Widevine DRM
By freaknik in forum Video Streaming DownloadingReplies: 4Last Post: 21st Jun 2017, 17:43 -
Looking for anyone with Google Widevine knowledge.
By cookeri6 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2017, 13:33 -
By cookeri6 in forum Video Streaming DownloadingReplies: 0Last Post: 15th May 2017, 12:45
