  1. i have a pioneer dv-343 and the vcd play good but the picture it have some square on the picture (like 5 time during a movie ) for about 5 sec and the sound skip to when it skip
    could be my software i use nero 5.5.8.0
    or could be my blank cd i use ambassador (cdr) and i try verbatim (cdrw) and no luck
  2. It could also be that your bitrate on your vcd exceeds 2600. That's the max for your player...any higher and you'll get the jerky playback you speak of.
  3. ok thanx i will try a other one that is less bytrate
  4. is there a software to change the bytrate of a video ?
