    Mar 2020
    México
    Rigth after launching the next message appears below on the status bar: "Autoloaded 54 filter(s) (1 failed). Check the log for details", then I go to the log and seems the ffvdub.vdf plugin module doesn't load because it's not a valid Win32 application. I installed ffdshow and took its ffvdub.vdf to replace VirtualDub's but no change in the message. If this plugin was what would make my Win10 machine show VirtualDub's preview, now I'm seeing what could be stopping it from doing so...
    How to make ffvdub.vdf load? Thanks
    Mar 2008
    Did you make sure to use the 32bit Vitualdub?
    Mar 2020
    México
    Hi davexnet, it's VirtualDub 1.9.11 (build 32842/release) by Avery Lee, I downloaded it from http://www.digitalfaq.com/forum/video-conversion/1727-virtualdub-filters-pre.html
    Mar 2008
    Try this version
    https://www.videohelp.com/download/VirtualDub-1.10.4.zip
    Also the FFdshow package has to be installed, otherwise the filter will not load
    Mar 2020
    México
    Ouch, same thing happens. Thanks anyway.
    Mar 2008
    I tested it myself using Vdub 10.4 and ffvdub.vdf (this version) in Windows XP (where I have FFDshow installed)
    it works fine
    Mar 2020
    México
    My mistake, VirtualDub's version was 32-bit, but ffdshow was 64-bit, now let's see if preview finally works under Windows 10... Thanks for everything davexnet!
  8. DECEASED
    Jun 2009
    Heaven
    ffvdub.vdf fails to load in VirtualDub
    Running 64-bit Windows 7 here, the 32-bit VirtualDub crashes after trying to load the ffdshow plugin.
    WORKAROUND: open the input video in GraphStudioNext, add ffdshow's raw video filter, save the .GRF file, open this latter with Avisynth's DirectShowSource().
    H.T.H.
    "Programmers are human-shaped machines that transform alcohol into bugs."
