  1. Banned
    May 2021
    turkey
    Hi,
    I'm using below command to save images from an ip camera. It saves jpeg files in yuv format. Can ffmpeg convert them to rgb ? Thanks
    ffmpeg -f MJPEG
    -y
    -i http://ip-address/cgi-bin/mjpg/video.cgi?channel=1&subtype=1
  2. iirc.
    ffmpeg -y  -f MJPEG -i http://ip-address/cgi-bin/mjpg/video.cgi?channel=1&subtype=1 -vf "format=pix_fmts=rgb48" directoryname/outputframename%d.png
    should output 16bit png rgb files (adjust the rgb48 to rgb24 if you want 8bit png)
    Cu Selur
