Hello.
Let me briefly draw the situation, I have D8 camcorder plugged via FW into ExpressCard inside my laptop, the moment I turn the camcorder on, PRemie Pro launches.
How to disable it? Premiere is not even my default NLE.
Results 1 to 9 of 9
Does Premier Pro have a service or startup program that starts with Windows?
Check that first -
"Programmers are human-shaped machines that transform alcohol into bugs." -
^^+1
If Win10 is like Win7 then the last Autoplay section concerns 'Digital Video' and there could well be a default capture program. Reset that to 'Take No Action' or something similar.
Premiere Pro probably set itself as the default DV capture app. There will be a setting somewhere in that, possibly as with other software as 'Devices', and that should be able to turn it off as well. -
try changing your startup programs - https://community.adobe.com/t5/premiere-elements/how-to-turn-off-auto-start/td-p/9894443
Is Final Cut Pro really that much better than Adobe Premiere Pro?
By videoguy102 in forum EditingReplies: 5Last Post: 9th Oct 2020, 06:34 -
Premiere Pro issue
By Kajaboss in forum MacReplies: 3Last Post: 17th Apr 2020, 08:07 -
Premiere Pro to Audition
By TORM3NTO in forum EditingReplies: 1Last Post: 24th Apr 2019, 10:43 -
Prevent XP Cyberlink 8 automatically starting when I use camcorder?
By hpcampr in forum Newbie / General discussionsReplies: 0Last Post: 19th Dec 2017, 19:32 -
Premiere Pro 5.1 Setup
By ziggy1971 in forum EditingReplies: 0Last Post: 15th Oct 2016, 19:05
