Hi,
So I have several srt files that have many lines with 2 words attached (that shouldn't be). Any idea how to fix that? I looked at the options in Subtitle Edit but couldn't find anything.
Thank you.487
00:20:42,806 --> 00:20:45,548
Ask that little boy versionof yourself.
488
00:20:45,592 --> 00:20:48,029
"How do I dance...louder?!"
489
00:20:48,072 --> 00:20:49,509
I don't know what you'retalking about, man.
490
00:20:49,552 --> 00:20:51,293
I don't know how to dance --Okay! Okay!
491
00:20:51,337 --> 00:20:53,164
Okay. Okay.
492
00:20:53,208 --> 00:20:55,384
I'm dancing louder.Okay?
Results 1 to 10 of 10
Open the SRT in Notepad and insert a space between the two words. Save.
Doesn't Subtitle Workshop have a spell checker? beyond that, I've no idea
You're right, the spell check is probably the solution, I've just tried it with both Subtitle Edit and Workshop, but you have to check one word at a time, and there are over 900 words that need fixing.
Is there a spell check that lists all the mistakes at once? (like when Subtitle Edit lists all the common errors?) so that I can maybe manually uncheck the ones it got wrong but then let it fix all the mistakes automatically? -
Try and google for a srt that doesn't have all those joined words.
For Station 19 episode 4-07 go to https://subscene.com/,they have a version that's doesn't have those joined words.
Thanks yeah, I mean there's no other version that syncs with the copy I have.
But it's fine I'll use the subs without the joined words and resync them, it'll be easier and faster than fixing the original subtitles.
Thanks. -
If your videos are from blu-ray/dvd/amazon then it will be really hard to resync the subs due to different run times and scene changes/durations.
Insert "beep" audio to black out words in a mp4 file
By IngvarEkstrom in forum Newbie / General discussionsReplies: 18Last Post: 30th Dec 2020, 13:24 -
Any Video Converter subtitles not in separate file
By GQuack in forum Video ConversionReplies: 10Last Post: 24th Apr 2019, 18:54 -
How can a file with subtitle muxed be smaller than when separate?
By bizzybody in forum SubtitleReplies: 1Last Post: 26th Apr 2018, 17:10 -
megui splits file into 2 separate files
By gtx780 in forum Video ConversionReplies: 5Last Post: 10th Nov 2017, 09:46 -
Attached a soft-sub srt to a mkv movie, having some errors in the new subs.
By TheFG in forum SubtitleReplies: 2Last Post: 23rd Aug 2017, 19:27
I meant is there a way to detect and fix those in a batch mode, there are literally hundred of words that are missing a space.
