Hey guys, I have been struggling with Netflix Quality Check errors on my subtitles. I have my subtitles timed and set correctly to my timing and movie frame rate (25FPS).
I am still getting "Minimum two frames gap" error. When I try to use "Apply minimum gap between subtitles" tool and set it to correct 80ms (2 frames in 25FPS) it just shows nothing to fix (since I have already used it before to fix this).
I dont seem to understand what this error is, would somebody be so king and explain me what am I missing?
I would appreciate your input a lot.
UPDATE: It was a bug fixed in 2.6.0 BETA.
Results 1 to 1 of 1
Subtitle Edit - Check split lines when character limitation not met
By whatcrisis in forum SubtitleReplies: 3Last Post: 27th Dec 2020, 12:42 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 18:33 -
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 11:37 -
Extracting IDX subtitle from netflix!
By DuplePlay in forum SubtitleReplies: 4Last Post: 16th Apr 2017, 18:39
