Was in doubt whether to ask it here or over at the Video board but here it goes. What would be the most convenient method/tool to try synch/mux a VHS video capture of a live stage performance of a song, which itself carried a damaged audio of the said performance, with the same performance but from another source, namely from an audio tape, where the sound quality of the said performance is much better. What would be most suited way to try set it in synch and to control the process both visually and by ear at the same time. Can it be done in VDub, something with the delay/skew options etc?
The best way would be to convert the original audio to uncompressed pcm (wav) format and the good (new) audio too, then load both wav files in an audio editor, g.e. Audacity and try to get the new audio in synch with the original one. Then save the new audio, convert it to what you want (ac3, aac...) and mux it to the video.
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 07:43 -
Audio from two devices cannot be synched.
By SF01 in forum AudioReplies: 3Last Post: 16th Nov 2019, 15:50 -
Tutorial on making a video with written lyrics of an audio/song?
By remtin in forum EditingReplies: 7Last Post: 24th Nov 2018, 01:24 -
Avisynth - Audio track longer than video track
By martanius in forum AudioReplies: 4Last Post: 18th May 2018, 03:13 -
How to use TSMuxer to make AC track primary audio (instead of AD)?
By itm2 in forum Video ConversionReplies: 0Last Post: 4th Apr 2017, 06:20
