I just need to address the above:
I did install and try your software, in fact I have it up an running as I type this. The GUI is poorly laid out, there is nothing intuitive about it.
You have scaling/spacing issues.
Your app automatically creates "proxy PRORES-lookalike" files, what the hell is a "PRORES-lookalike" file? And why does your software also want to transcode to this format when the source is already PRORES?
Your GUi also has issues with freezing up, it stays frozen in place and can't be moved, either in full screen or scaled.
There is no way you have been "programming professionally since 1998", if you were really coding since then you would never have chosen C#, you would have used Pascal/Delphi or C++ and you wouldn't have made the amateurish programming mistakes you made.
Lastly, your pricing is silly. Lightworks, which can claim use by legit professionals only costs $526 for an outright license and it comes with 2 additional pieces of software and it works on Linux, Windows and OSX:
https://www.lwks.com/index.php?option=com_content&view=article&id=103&Itemid=214
https://www.lwks.com/index.php?option=com_shop&view=shop&Itemid=205
The monthly fee for Lightworks, if one wants a subscription is just $30 and it supports RED, R3D, DPX, RAW, GPU accelerated color correction, various hardware devices, stuff that your app doesn't come close to supporting.
Magix Video Pro X costs $400 and supports 8K HDR, GPU acceleration, AVX optimizations. Forget about competing with Vegas Pro 18, which also cost $400 and supports HDR, 32 bit float processing, and hardware-accelerated lossless intermediate formats.
I'm not going to go through all the other alternatives, but if you were giving it away for free it still wouldn't be worth the time, there are much better legally free alternatives, but at the fees you want to charge, one would have to be drunk or high to consider it.
Closed Thread
Results 31 to 42 of 42
1. The GUI is not poorly layed out, just just wanted to bash it.
2. Scaling/spacing issues - perhaps, I have tested it at 100% and 200% scaling. And, I'm testing at 1920 x 1080. On smaller monitors, it might not look as great. That being said, I will take another look at how it would look at 1600 x 900.
3. I honestly don't care about your "programming advice" - or whatever you'd call it. There are millions of C# programmers out there who strongly disagree with you. And in fact, I've programmed C++ about 12 years before moving to C#.
4. GUI freezing: if it's for a 2-3 seconds when moving from one layer to another -- this is something I'm currently working on -- should have an update by end of the week. This issue arose when I added keyframes - a few days ago.
5. About my pricing - that's fine. You don't like it, don't buy it. If it brings you value, you'll buy it. If not, stick with what you like.
John @ Cinematic StudioLast edited by cinematicstudio; 29th Apr 2021 at 22:51.
I am going to prove how pathetic your software is with a video of me attempting to us it.
Test system is a 17" HP laptop, i5-1035G1, 4C/8T, 16gb ddr4-2666, 1tb NVMe, 1tb SSD.
Test methodology. did clean install of Cinematic Studio, launched app, tried to load test video linked below, the recording below is from my 3rd attempt.. While waiting, launched Shotcut and loaded file into timeline, to show that it is a valid video file and other video editors handle it just fine. Shut done Shotcut, checked if Cinematic Studio had loaded test file or if GUI was working properly, confirmed neither was the case, launched OpenShot, loaded test file, showed that OpenShot handles file just fine, shut down OpenShot, checked on Cinematic Studio, saw no progress, shut it down.
Test video:
Video
Format : ProRes
Format version : Version 0
Format profile : 422
Codec ID : apcn
Duration : 1 min 5 s
Bit rate mode : Variable
Bit rate : 907 Mb/s
Width : 6 144 pixels
Height : 3 456 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:2
Scan type : Progressive
Bits/(Pixel*Frame) : 1.779
Stream size : 6.88 GiB (100%)
Title : Core Media Video
Writing library : abm0
Encoded date : UTC 2019-08-02 08:25:59
Tagged date : UTC 2019-08-02 08:28:15
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 1 min 5 s
Bit rate mode : Constant
Bit rate : 320 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 2.49 MiB (0%)
Source stream size : 2.49 MiB (0%)
Title : Core Media Audio
https://www.blackmagicdesign.com/products/blackmagicpocketcinemacamera/workflow
^Look for the file named Indie Film, ProRes version.
People can judge for themselves what a half-baked, sorry excuse for a video editor you are trying to peddle.
Note that you can not drag the app window, text is misaligned, nothing happens when you try and load a file and the overall layout is asinine.
Let me stop your "demo" right there:
You are a troll. There's no reasoning with a troll. Anything you say, the troll will find something regardless of the topic, to "say" back, just so he feels the pleasure of having the last word. In his mind, that's how he "wins".
To spend more time arguing with you, is simply a waste of my time. Which I'd rather spend programming.
To everybody else watching his "demo":
1. First of all, he's got a low screen resolution (1600 x 900). On such a low resolution, he increased the dpi to 125%, just so that the app will look even more cramped. I did say I optimized the app for Full HD + dpi = 100%, so thare's really no surprise here -- if you have a decent monitor, even on 125%, it will look ok. If people genuinely using my app will report this to me, by all means, I will look into it.
2. There's a reason each of the panes has a min size - so you can see what it's supposed to show you -- however, if you have a bike and want to drive like Lambo, it's not going to work (meaning, screen real estate). My app is optimized to be full screen, to take as much space as possible. It's pretty logical, it's a video editor, and you do need a lot of space.
3. His .mov file - maybe he manually broke it, whatever. I will tell you this - I use Windows API to process the .mov file. If there's a bug in the Windows API for that specific .mov file, I won't be able to process the file. Also, pretty sure Shotcut doesn't use Window API to process the .mov file, so if the file is malformed, its processing library has a way to work around it. As a side note, in the future, I will work on porting my app to use ffmpeg, so maybe, if this was an actual issue, it will go away.
LATER EDIT: i downloaded his video, and as I suspected, the Windows API can't play it -- since it's BRAW. To test what I'm saying, simply download his video, and try to play it with "Movies & TV" app. I do see that ffplay can play it, so when I will port to ffmpeg, this will work.
4. If you have a problem with my app, unless you report it, I can't fix it.
If you are genuinely interested in my app, even just for curiosity, I will welcome all feedback. I never said my app would be perfect, it will always be a work in progress. That will be shaped by the people using it. There may be a few bugs now and then, I do struggle to fix them all, but some will slip by. If you encounter any, please report it at cinematic @ cinematicstudio . app, and I will certainly look into it -- the more details you provide, the easier it will be for me to find and fix the issue.
Thanks!
Best,
John @ Cinematic StudioLast edited by cinematicstudio; 30th Apr 2021 at 15:38.
i5 Laptop?
I'm out.
Don't even bother.
Shotcut will run on a triple A battery.
As for the tone of that reply about how 'pathetic' it is , now you are just being rude for the sake of it.
As least be decent and give critical remarks, insults lose your corner.
You had my respect to begin with, and lost it at 'Pathetic' and how YOU had to prove something.
If you're going to provide proof, you need to have the hardware to do it according to the software 'minimum specs'Last edited by super8rescue; 30th Apr 2021 at 17:00.
So you are a liar. I posted the link and instructions stating to download the ProRes version of the file, and I posted the MediaInfo for the test file.
It's sad that you don't know that ffmpeg does not support BRAW, neither does Shotcut nor Openshot or any app that relies on ffmpeg.
You still have not explained what "ProRes-lookalike" means, you haven't explained why you feel the need to transcode every file to that format nor have you explained why you feel the need to transcode files that are already ProRes to that format.
Yes, the laptop uses 1600x900 but Shotcut, Openshot, Resolve, Vegas, AviDemux, all work fine, no other editor has a problem with that resolution, your app does, that means you F'd up with the coding.
You can call me a troll all you want, but the fact remains that you want to charge $600 per year for an app that doesn't work and is feature starved.
Your "software" is garbage, poorly coded, poorly laid out and its developer clearly has a way overblown high opinion of it.Last edited by sophisticles; 30th Apr 2021 at 21:49.
Using this laptop I can edit 12k video using Resolve, not smoothly, but it's possible, 6k video relatively smoothly with Shotcut, Openshot, Vegas, Video Mastering Works and Premiere.
His 'minimum specs' is indicative of poor coding techniques, inadequate optimization and a bloated programming language.
In your post #23 you talk about value compared to price. I would regard even your Lite version as very poor value for money. It's 2021. The majority of people who may use this app would not be using 720p, especially as phones, these days, shoot in HD and UHD.
As an aside, I also notice on your website that no mention is made of supported codecs.Canon C100 mk2 - Dell XPS8700 i7 - Win 10 - 24gb RAM - GTX 1060/6GB - DaVinci Resolve Studio 18.6.3 - Blackmagic Speed Editor - Presonus Faderport 1 - 3 calibrated screens
Contact https://cinematicstudio.app/ if you want to continue discuss this software. Thread closed.
VSDC free editor changing speed of video
By Alianco in forum Newbie / General discussionsReplies: 10Last Post: 6th Jun 2020, 10:31 -
VSDC video editor: change speed of multiple layers
By pdxlion in forum Newbie / General discussionsReplies: 1Last Post: 31st May 2020, 00:18 -
Speed up video to restore original playback speed?
By nekrosoft13 in forum Video ConversionReplies: 6Last Post: 30th Nov 2019, 00:16 -
Why does my video editor "cache my video to speed things up"?
By Mark01 in forum EditingReplies: 4Last Post: 19th May 2019, 23:37 -
Video editor that allows you to slow down/speed up
By insidesafstand in forum EditingReplies: 3Last Post: 7th Aug 2016, 06:29
