I have some old files encoded with wmv2 and I tried to open one of them but the video is speeding up from time to time and then slowing down to normal speed. As a result I get 4 seconds shorter video file. Has someone experienced a similar problem and how can I solve it?
Start by saying with which software you played the problematic files.
Since those .ASFs are old, PERHAPS some data corruption happened, but this is just a wild guess"Programmers are human-shaped machines that transform alcohol into bugs." -
Give a try to DirectShowSource and set convertfps=true to obtain a sane framerate value (e.g., 25 or 30 fps).
Also, make sure that LAV filters (and not the native Windows demuxer and decoders) are being used."Programmers are human-shaped machines that transform alcohol into bugs." -
Thank you a lot for the help, definitely the video has VFR and it made problems with decoding. But everything is decoding properly with DirectShowSource.
Opening Wv files
By carlmart in forum AudioReplies: 2Last Post: 7th Jan 2021, 08:01 -
Quicktime Pro crashes when opening 700GB file on RAID drives.
By digicube in forum EditingReplies: 10Last Post: 9th Jan 2020, 22:31 -
VirtualDub2 - misses frames when opening MTS file
By rgr in forum EditingReplies: 2Last Post: 14th Dec 2018, 05:32 -
Viewing WMV2 media - natively in Quicktime
By intelmini in forum MacReplies: 3Last Post: 1st Jul 2016, 10:15 -
MeGUI freezes while opening d2v file.
By ZikO in forum Video ConversionReplies: 7Last Post: 17th Jun 2016, 04:33
