Results 61 to 64 of 64
I am referring to resulting RGB values. I made nearly a dozen tests on different DVD's, with the same settings, and got significantly different results, just in the letterbox "black" area.
Strange. I can imagine that rounding effects during YUV -> RGB conversion give +/-1 unit deviations, but 8 steps seem to be too much .....
+/-3 for color
+/-0 for black,white,greyscale where CbCr are 128
Or home video can be +/- 50. Seriously.
But are you just ripping the DVD and measuring digital values directly, or contaminating the results through some capture chain ?
The actual digital letterbox values will be Y=16,CbCr=128 . RGB 0,0,0 if using "computer RGB", or RGB 16,16,16 if using "studio range RGB"
Histogram for Amarec TV
By Alwyn in forum Capturing and VCRReplies: 15Last Post: 3rd May 2023, 08:05 -
play video with histogram display, avisynth+ ?
By butterw in forum Newbie / General discussionsReplies: 44Last Post: 14th Oct 2020, 04:22 -
Capture Codec Setting, Crushed Black Levels, Histogram use
By Smells_Like_Feet in forum Capturing and VCRReplies: 8Last Post: 10th Aug 2020, 10:31 -
Interpreting the effects of 'separatefields'
By pooksahib in forum Video ConversionReplies: 4Last Post: 4th Mar 2017, 00:27 -
AviSynth 'Histogram' is Suspicious
By WinUser in forum Video ConversionReplies: 13Last Post: 23rd Feb 2017, 08:49
