Hello,
I capture NTSC laserdiscs and ran across GlitchBob's post about dot crawl removal. Being how laserdisc is composite video, I have an external 3D comb filter in the chain. My player's built-in comb filter is decent, and maybe good enough to eliminate the external comb filter if I can figure out which AVISynth plugins64 to get rid of the rest of the rainbow/dot crawl that the player's filter doesn't scrub.
If anyone has experience with using any of the Rainbow & Dot Crawl removal filters, could you please take a look at the clip and possibly advise me of a script? I can see the dot crawl better when I step frame-by frame vs. in real-time playback. Pay close attention to the pool ladder handles.
Try this:
There's still a little flickering rainbow artifacts.Code:CheckMate() # reduce dot craw (may create ghosting on some material) TFM() TDecimate() dehalo_alpha(rx=2.0, ry=1.0) # optional oversharpening halo reduction Santiag(strv=1, strh=1, nns=4) # clean up chroma chroma interlacing artifacts MergeChroma(aWarpSharp(depth=5), aWarpSharp2(depth=10).Sharpen(0.5)) # sharpen luma a little, chroma more
Reducing severe dot crawl?
By GlitchBob in forum Video ConversionReplies: 6Last Post: 19th Apr 2021, 23:35 -
AviSynth Add Rainbow/Dot Crawl Plugin Issues
By Loyaldk in forum Newbie / General discussionsReplies: 11Last Post: 11th Feb 2021, 11:25 -
Removing dot crawl and rainbowing artifacts from NTSC dvd rip
By pm-s in forum RestorationReplies: 9Last Post: 1st Feb 2021, 05:07 -
Best way to remove dot crawl and rainbow?
By embis2003 in forum RestorationReplies: 13Last Post: 27th Mar 2020, 12:12 -
Dot Crawl remover changing colors?
By killerteengohan in forum RestorationReplies: 0Last Post: 17th Feb 2017, 16:11
