    Apr 2021
    Europe
    Hello everyone. I have a problem with DVDStyler. I converted an mp4 file to DVD with this program but when I go to play it with PotPlayer the video is jerky, laggy. How do I fix this?
  2. Hello, which version of DVDStyler did you use (stable or latest beta)?
    Which settings did you choose for quality, etc.
    I tested the program for creating two DVDs and the highest quality settings should use a higher GOP rate, so you will get a few graphic errors if you seek to a special position in the video.
    Apr 2021
    Europe
    DVDStyler v.3.1 64bit
    As for the settings I haven't changed anything, they are the default ones.
    However if I play the vob files in the dvd folder individually they work perfectly. The problem is when I play from open folder in potplayer.
    Mar 2008
    Have you tried an alternative player such as mpc-hc?
    Apr 2021
    Europe
    Sorry for the delay in replying. But I've been busy.
    It seems that with Vlc it works
