I have a Plextor Blu Ray player that I got 10 years ago or so. I thought it could play BD-R discs. Here is the player:
https://www.cnet.com/products/plextor-px-b310u-bd-re-hd-dvd-rom-combo-drive-usb-2-0/
Is there a way to update it at all, or should I look for a new player? Thing works like a charm but I'd hate to get rid of it just because of one disc.
Results 1 to 10 of 10
Did a quick google of your drive and looks like latest firmware update is 1.06
You might want to check your drives FW version. Unfortunately, there is no description of what features version 1.06 fixes or adds. -
OK, so much for the FW. BTW, when you say "play the BD-R" are you saying the BD disc contains the format of a blu-ray video disc or are you trying to "read" data files from the BD-R disc? Any BD-ROM drive should be able to "read" any files from a BD-R. Or maybe not, in your case. LOL
It's a Blu-Ray disc, the player just acts like nothing was put in. Maybe I just got a bad disc, or I have to try it on another player just to make sure.
Oh, so it's a commercial BD disc (not a BD-R writable disc). Makes a difference. What SW are you using to "play" the BD? So the OS can see the BD but not the player SW.
The OS can see the Blu Ray drive, but not the disc inside. I open up MakeMKV and it tells me "No disc inserted". There is one other thing:
I bought the disc from an online store, it is Region Free. Other notes include "Note for best playback: Item will play best in regular standalone Blu-ray players and also on a ps3 and ps4. Item won't play on a xbox, xbox one, or xbox 360."
That's the whole story. I figured this Blu-Ray Player was still advanced enough to recognize such a disc. -
Sounds like a very unusual BD disc. If OS can't see it then you may be out of luck. Like you said, it's only this disc. Never heard of such a thing. Good luck.
You should test the disc on a stand-alone Blu-ray player or one of the compatible game consoles, Technically speaking, you have a Blu-ray reader & CD/DVD burner combo optical drive that relies on software running on a computer for disc playback, so it is not exactly the same as a stand-alone Blu-ray player.
Movies released in limited numbers and custom burned to disc sometimes have defects or an unusual type of copy protection that interferes with playback, according to some posts that I have seen on VideoHelp.Ignore list: hello_hello, tried, TechLord, Snoopy329
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 13:02 -
Sony BDP-S370 Blu-Ray Player does not detect USB Drive?
By Shreeux in forum DVD & Blu-ray PlayersReplies: 6Last Post: 12th Jul 2019, 13:15 -
Can a Blu-ray player play Blu-ray video burned on a DVD?
By digicube in forum Blu-ray RippingReplies: 2Last Post: 16th Jan 2019, 02:11 -
Sony BDPS6700 4K Upscaling Blu-Ray Disc Player/Make Multi Region Player
By swu1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Nov 2017, 16:05 -
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 08:32
