Dear friends,
I´m using AVI_IO under Win98 SE, and when my capture file is over 7Gb, the frames dropped gets crazy !!! And I need to stop the capturing. Is it a FAT32 problem ? Should it be solved with a NTFS system file ?
Please help me ...![]()
Hey man, I'm from Brazil too. Whell I don't thing NTFS is the best option because it is lower than the FAT... but i really don't know what happenning...
Malz, Flw! : ) -
Dear friend,
A friend told me that my capture card, a Pinnacle DC10 Plus, have a bug , and after 71 minutes of capturing, the card goes nuts. And it really happens here.
So, I´ll change the setting and see what happens.
Thanx for the help.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 05:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 13:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
