I am a Novice with PGC edit. I would like to change a button's associated tile. Basically a button plays the wrong title and I want to preserve all the menu functioning but change one button to play a different title. Thanks ahead of time.
I've only did this once using this link.
https://forum.doom9.org/archive/index.php/t-102141.html
The link assumes some familiarity with PgcEdit.
In my case I had to create a new dummy pgc (step 7 in the tut). -
Hint: Use the Trace mode to discover and analyse the commands that the button executes to lead to the wrong title. Usually, it is sufficient to modify a single value in one of these commands or in the command of the button itself to go to another title.
If it's too complex for you, use Info -> DVD Commands and post the result here (between [CODE] tags please). And of course, tell us what button must be modified, and what title should be the correct target. I'll try to help.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
"Rolling edit" in Subtitle Edit
By Aukikco in forum SubtitleReplies: 1Last Post: 7th May 2019, 09:08 -
DVD Decrypter - which PGC to select
By pooksahib in forum DVD RippingReplies: 4Last Post: 17th Dec 2016, 07:19 -
Adding subtitles to existing DVD + keep original menues - problem PGC files
By guy24s in forum SubtitleReplies: 7Last Post: 7th Oct 2016, 05:18 -
edited DVD using DVD Shrink / Muxman / PGC Demux - differences in total
By efc1978 in forum EditingReplies: 7Last Post: 11th Aug 2016, 03:29 -
editing 2-3 times with DVD Shrink / PGC Demux delay correct?
By efc1978 in forum EditingReplies: 2Last Post: 9th Aug 2016, 04:02
