Hello,
if I remember correctly, I saw another thread here in the forum about this topic but I can't find it anymore.
Anyway, I have a video here probably shot on film which is mixed with which seem to be interlaced parts.
What would be the best method to deinterlace or maybe IVTC the video?
Sample attached.
There is nothing interlaced in terms of content. There are frame repeats with extra fields, that's why you see "combing" in some sections. The highest content framerate is 25 samples/sec . (Interlaced content would have 50 samples/sec)
So, just field match
Code:FFVideoSource("example.avi") AssumeTFF() TFM() -
Somehow now I get the error "There is no function named TFM". I already put the DLL in the plugins folder, but it still gives me that error.
https://github.com/pinterf/TIVTC/releases
What avisynth version ? What plugin version ?
It might be that you are using mixed x86, x64 pathways
What application are you using ? Its it the same as your avisynth version ?
eg. If you're using vdub2 x64, you'd need avisynth x64, and the x64 version of the TIVTC.dll plugin -
AviSynth+ 3.6.1, plugin version: v1.0.26 (TIVTC-v1.0.26.7z, x86)
Plugin is in the "plugins+"-folder.
[Attachment 58574 - Click to enlarge]
I am using VirtualDub2 Build 44282/release x86.
EDIT: I put the plugin mistakenly in the folder of a older AviSynth+-Version I am not using anymore. That's why it didn't work. It does work now.Last edited by phelissimo_; 24th Apr 2021 at 12:45.
Deinterlacing Progressive PAL with Interlaced fades (PAL Hybrid)
By ajingo in forum Video ConversionReplies: 11Last Post: 17th Dec 2020, 12:14 -
VMS : Mixed progressive/interlaced timeline
By smartel in forum EditingReplies: 24Last Post: 2nd Aug 2019, 21:11 -
59.940 to 23.976, mixed progressive and interlaced?
By amaipaipai in forum Newbie / General discussionsReplies: 13Last Post: 23rd Jun 2019, 20:00 -
Mixed progressive and interlaced source
By gamjerr in forum Video ConversionReplies: 2Last Post: 4th May 2018, 22:59 -
Best way to convert from progressive to interlaced in mixed footage project
By Nedo in forum Video ConversionReplies: 11Last Post: 18th Nov 2017, 09:57
