Any suggestions for a good but easy to use MKV editor, I want to cut/edit certain action sequences from MKV files I have ripped from DVDs. I only intend to apply basic fade effects and ideally if easily done, slow the framerate down.
You can only cut on I frames in a MKV container so you may not be able to edit precisely where you want to.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
If you don't mind reencoding (and the concommitant loss of quality) you can cut anywhere you want. If your MKV files contain MPEG 2 video from DVDs (typically made by MakeMKV) there should be keyframes about every half second. If that's sufficient for you there are several editors (you may have to remux from MKV to MPG to use them) that can cut on keyframes with no loss of quality. There are also "smart" editors that can cut MPEG2 with frame accuracy and only reencode the cut GOPs.
MKV Tag Editor
By gonwk in forum Newbie / General discussionsReplies: 32Last Post: 24th Jan 2021, 10:39 -
Need simple MP4/MKV (etc) metadata (at least codec id) editor
By Sinsearach in forum EditingReplies: 1Last Post: 26th Jan 2020, 15:20 -
[editing] easy switching between clips in VSDC or another free editor
By PawelK in forum EditingReplies: 5Last Post: 8th Sep 2019, 11:53 -
MKV Tag Editor commands
By ClearBlueSky85 in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2017, 14:02 -
Software to batch editor media info in e.g *mkv *mp4 files
By euphonic in forum EditingReplies: 9Last Post: 12th May 2016, 14:11
