Hello everyone. I'm kinda new using Neat Video but I've been impressed with the results. I use VirtualDub and set the profile with the video itself. If I want to remove all the noise from a whole Anime DVD movie, can I just set the profile once and run the whole thing? Or should I split the movie by scene and set a profile per scene? Obviously that would take longer but I want the best results. Would that make a difference? Thanks everyone
The end results that Neat Video produces relies heavily on the profile used.
It's unlikely that a whole movie would have the same characteristics (e.g. some dark scenes, some bright scenes) , so you will generally get better results dividing up and grouping into similar sections
You can do some tests on small sections and see if the extra effort is worth it for your specific case -
Neat video has some very nice feature "adapt to changing noise" which is deselected by default and can help in longer videos with changing scenes. Version 5 is much improved over ver 4 faster and with some nice features which makes it unique noise remover not seen in avisynth filters. One bad habit that I noticed working with it over couple of years is that it tends to "colorize" or alter color in some areas ( putting strange cyan on hands or part of the face) on low res videos like vhs which is easy repaired with ccd filterThe end results that Neat Video produces relies heavily on the profile used.
It's unlikely that a whole movie would have the same characteristics (e.g. some dark scenes, some bright scenes) , so you will generally get better results dividing up and grouping into similar sections -
Thanks everyone. I'll check out the "adapt to changing noise" selection. I did notice microscopic differences when I split the movie, but nothing that would be obviously seen. Maybe it's not worth the time. Thanks again!
Restoring movie trailers from various sources
By TenementLady in forum RestorationReplies: 0Last Post: 26th Oct 2020, 08:19 -
Neat video "colorizes" wrong color hands and face
By mammo1789 in forum RestorationReplies: 4Last Post: 25th Aug 2020, 16:21 -
Avisynth anime restoring
By BeyondTheEnergy in forum RestorationReplies: 11Last Post: 13th Aug 2018, 12:55 -
is neat video my best option
By hdfills in forum RestorationReplies: 9Last Post: 25th Aug 2017, 13:57 -
Neat Video
By timsky in forum RestorationReplies: 2Last Post: 11th Aug 2016, 20:11
