I've downloaded many files, but a handful have had glitches, bad frames, or lord knows what. When I load them into vcdeasy, the file will scan up till the bad frame and then stop, preventing me from creating a complete bin file. For some reason I CAN burn the complete file with nero, but it won't let me add chapters which I would like to. I've tried using vcdgear, but it seems to just split the files into 2 pieces, dividing them at the glitch. Tmpegnc won't join them back together. Any suggestions short of actually reencoding them?
try the Merge&Cut tool in TMPGEnc
I use it to fix errors -- it works pretty good
your not really doing a Merge&Cut but it seems to re-write and re-calculate the header - just make sure to select the correct SVCD typeyour pal,
Stinky -
I tried using the merge and cut, but it stopped at the same places in the files as vcdeasy does.
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
No audio track when importing mpeg2 into sony vegas? How do I fix this?
By bojadada in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2009, 10:53 -
how to fix "WARN: unknown mpeg2 aspect ratio 1" in DVD Author GUI
By extent in forum Authoring (DVD)Replies: 10Last Post: 23rd Nov 2009, 07:57 -
question about how to "Fix" non-standard mpeg2 files
By jimdagys in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2008, 08:24
