Results 1 to 12 of 12
    Apr 2021
    California
    I'm trying to compile a DVD using DVD Lab Studio, and every time I remux the files the runtime doubles. The audio is fine, but the video is choppy and basically runs at half speed. What could be causing that, and how can I fix it?
  2. Post a mediainfo report of both files (video+audio, if separated) here.
    Apr 2021
    California
    I downloaded and installed that program, and I opened the first file, but the program is not very intuitive, and I have no idea what to do next. Is there some information in particular you were interested in?
  4. Drag/Drop your video onto MediaInfo. Set View -> Text (if not already). Copy (Ctrl+C) / Paste (Ctrl+V) the text to a post here.
    Also, MediaInfo probably set up a Shell command. You should be able to right click on a video and select MediaInfo from the context menu.
    Apr 2021
    California
    Thanks for the help. I hope I did it right.
    The original file is an MPG created with Video Redo, and it seems fine.
    MPG file before compiling:
    (Video Redo and DVD Lab both report runtime as 2:27)
    General
    Complete name : F:\DVD\4 - Projects\Dexter\Dex 1a ready.mpg
    Format : MPEG-PS
    File size : 4.63 GiB
    Duration : 2 h 27 min
    Overall bit rate : 4 484 kb/s
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings : BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : Variable
    Format settings, picture structure : Frame
    Bit rate mode : Variable
    Bit rate : 4 139 kb/s
    Maximum bit rate : 5 000 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.400
    Time code of first frame : 00:00:00;00
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Stream size : 4.28 GiB (92%)
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.601
    Matrix coefficients : BT.601
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Bit rate mode : Constant
    Bit rate : 256 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Frame rate : 41.667 FPS (1152 SPF)
    Stream size : 271 MiB (6%)
    Text
    ID : 224 (0xE0)-CC3
    Format : EIA-608
    Muxing mode, more info : Muxed in Video #1
    Stream size : 0.00 Byte (0%)
    CaptionServiceName : CC3
    After DVD Lab Studio compiles the video, the resulting VOB files are out of synch, audio is normal, but video plays 1 sec, pauses 1 sec, repeatedly
    VOB file after compiling:
    (DVD Shrink reports full runtime as 4:52)
    NOTE: This text is for VTS-01-1 (first segment) only
    General
    Complete name : F:\DVD\Dexter 1a compiled\VIDEO_TS\VTS_01_1.VOB
    Format : MPEG-PS
    File size : 1 023 MiB
    Duration : 54 min 51 s
    Overall bit rate : 2 607 kb/s
    Video
    Format : MPEG Video
    Bit rate : 2 299 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.222
    Time code of first frame : 00:00:00:00
    Stream size : 902 MiB (88%)
    Audio
    Format : MPEG Audio
    Bit rate : 256 kb/s
    Stream size : 100 MiB (10%)
    Text
    ID : 224 (0xE0)-CC3
    Format : EIA-608
    Menu
    Mar 2008
    Can you provide the log from DVD Lab and post it here
    Are you using double layer DVD's? Because the source looks like it's too big @ 4.63 GB
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Is the original "DVD" from a DVD Recorder? Sometimes they author DVDs that point to the material twice.
    Apr 2021
    California
    I would be happy to provide the "log" from DVD Lab, but I don't what it is or how to obtain it. The original files were not recorded, they were ripped from the commercial DVD using DVD Shrink in "reauthor" mode. The file seemed fine until I tried to compile it. I only use single-layer discs. I should also add that I've made over a hundred DVD compilations, and this never happened before. I was looking at the Mediainfo report, and I noticed that the bitrate changed during the compilation process. In fact it was cut in half, so I'm wondering if that has something to do with it. If so, how can I fix that? If not, what should I do next?
    Mar 2008
    What is your source from dvd shrink? Mpeg file?
    Try Avstodvd instead of dvd-lab. If the source is already compliant, it will not re-encode it, just pass it to the authoring stage (muxman)
    Apr 2021
    California
    Ripping with DVD Shrink creates VOB files. After I ripped the episodes I wanted, I joined them with Video Redo into a single MPG file. Then I compiled the MPG using DVD Lab, which converted it back to VOB files, ready for shrinking and burning. I've done this dozens of times, but this time the resulting VOB files are twice as big, the synch is off, the video stutters, and the bit rate is halved. I can't figure out why the process didn't work this time. Apparently the reduced bit rate causes the video to play, then freeze, then play, then freeze, doubling its runtime, but what causes the bitrate to change? I tried compiling the material without demuxing, but that created audio errors. Before I try a different program, I'd like to understand what's happening here and why. Any ideas?
    Mar 2008
    No because I'm not familiar with DVD-Lab at all. I installed it and I'm taking a look - if I spot anything
    I'll add to the thread.
    The bitrate is average. Unlikely the rate of any single VOB will match the source file.
    You need somebody familiar with the quirks of this program to help you
    Try this suggestion
    http://forum.doom9.org/showthread.php?p=516162#post516162
  12. Originally Posted by rw1954 View Post
    Maybe the single episodes are different. Post a mediainfo report from each single episode here.
