I have a ts file.This is the mediainfo.
when I play the video,it's like a interlaced clip.
So I try to use QTGMC to solve this problem.This is the avs script:
LoadPlugin("xxxx\LSMASHSource.dll")
LWLibavVideoSource("xxxx\test.ts")
QTGMC(Preset="Slower")
but it doesn't work,the output clip just double the frame by copy the frame.it means frame 2 and 3 are the same,4 and 5 are the same and so on.
I try to useQTGMC(Preset="Slower",InputType=1 or 2 or 3), but none of them work.
If there is a solution, I will greatly appreciate! Thank you!
It doesn' look like it's interlaced if the pairs of frames are the same, you may have to upload a sample if you want a definitive answer
I agree. It looks to me like it's been blend-deinterlaced already, and is therefore progressive. As davexnet suggests, upload an untouched sample.
can x264VFW deinterlace?!?
By marcorocchini in forum Newbie / General discussionsReplies: 5Last Post: 15th Apr 2019, 08:11 -
1080i deinterlace
By max_cady in forum Video ConversionReplies: 4Last Post: 8th Apr 2019, 11:25 -
Do you need to Deinterlace when Downscaling Progressive Video?
By VideoFanatic in forum Video ConversionReplies: 7Last Post: 8th Apr 2018, 16:43 -
detelecine/deinterlace options for NTSC DVD: 1 progressive to 5 interlaced?
By U2Joshua in forum Video ConversionReplies: 29Last Post: 9th Dec 2016, 11:38 -
Progressive Frames Deinterlace
By TheLastOfThem in forum Video ConversionReplies: 13Last Post: 11th Jul 2016, 18:17
