Try StreamFab All-in-One and rip streaming video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
    Apr 2021
    Freedumb
    I am currently using Topaz Video Enhance AI to do some processing on an HDR film.
    I believe this is the relevant info from the video file.
    Color space                    : YUV
    Chroma subsampling             : 4:2:0
    Bit depth                      : 10 bits
    Bits/(Pixel*Frame)             : 0.148
    Color range                    : Limited
    Color primaries                : BT.2020
    Transfer characteristics       : PQ
    Matrix coefficients            : BT.2020 non-constant
    Mastering display color primar : Display P3
    Mastering display luminance    : min: 0.0050 cd/m2, max: 4000 cd/m2
    Maximum Content Light Level    : 910 cd/m2
    Maximum Frame-Average Light Le : 310 cd/m2
    I'm having VEAI output to 16-bit TIF that reports being in rgb48le format.
    I have no experience in HDR content and wanted to know if that image output would be correct/enough to be able to use ffmpeg to stitch a video back together then take and reapply the HDR profile from the original source to the new file? And if so how would I go about doing so?
    This page that I found recently seems to be the method I want to take.
    https://codecalamity.com/encoding-uhd-4k-hdr10-videos-with-ffmpeg/
    With the processing seemingly being.
    -Extract metadata
    -Create video from images using HDR video properties and HDR metadata
    Is anyone able to verify if this process would work out?
  2. Extracting the HDR10 meta data with FFmpeg and later adding it back while converting with x265 to H.265 should work.
    Note the step described in that link do not extract and later add HDR-10+ or DolbyVision data.
    (Both of these could be extracted and later added again,..)
    Cu Selur
    users currently on my ignore list: deadrats, Stears555
