I have ben struggling with this for quite some time; Essentially what I'm trying to do is broadcast my webcam from within the Browser to Ffmpeg on the server to convert into a .m3u8 HLS live stream. But I am having a few problems with video playback I initially thought it was CORS and cross origin headers however now I am thinking its to do with the way I'm trying to encode the media.
I did a ffprobe on the input this was the response;
I am wondering if someone could help with the ffmpeg parameters; I am currently using the following;Code:SERVER:key destination set to:1618380585-6666-863686008-4444-21 FFMPEG:Input #0, matroska,webm, from 'pipe:': Metadata: encoder : Chrome Duration: FFMPEG:N/A, start: 0.000000, bitrate: N/A Stream #0:0(eng): Audio: opus, 48000 Hz, mono, fltp (default) Stream #0:1(eng): Video: h264 (Constrained Baseline), yuv420p, 640x480, SAR 1:1 DAR 4:3, 30.30 fps, 30 tbr, 1k tbn, 60 tbc (default)
I have also run into other problems and I was also wondering if i needed to build ffmpeg differently; here is the current build I am running; I only wonder this becuase when i try to add theCode:var ops=[ '-r', '17', '-i','-', '-strict', '-2', '-vf', 'scale=w=1280:h=720:force_original_aspect_ratio=decrease', '-c:a', 'aac', '-ar', '48000', '-b:a', '128k', '-c:v', 'h264', '-profile:v', 'main', '-crf', '20', '-g', '48', '-keyint_min', '48', '-sc_threshold', '0', '-hls_time', '4', '-hls_segment_filename', '/var/www/html/streams/segments/streamKey-date-%02d.ts', '-hls_base_url', '/streams/segments/', '/var/www/html/streams/streamKey.m3u8' ];parameter I get a response of not found.Code:-hls_playlist_type live
Code:ffmpeg version 2.8.17-0ubuntu0.1 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.12) 20160609 configuration: --prefix=/usr --extra-version=0ubuntu0.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Hyper fast Audio and Video encoder usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Results 1 to 1 of 1
How To Use ffmpeg to merge audio_only.webm with video_only.webm
By carlarogers in forum Video ConversionReplies: 3Last Post: 4th Aug 2020, 08:21 -
Recording .m3u8 live streaming - 403 Forbidden? :(
By gurmurad in forum Video Streaming DownloadingReplies: 5Last Post: 3rd Jun 2020, 08:48 -
Hi
By spyro10 in forum Video Streaming DownloadingReplies: 1Last Post: 7th May 2018, 01:46 -
HD/HDMI cameras, live video output
By jmstack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 9th Nov 2017, 20:32 -
Capture live streaming from website and convert to m3u8?
By johndii in forum Video Streaming DownloadingReplies: 3Last Post: 4th Jul 2016, 10:15
