I'm currently using handbrake but I've looked at the documentation and it seems handbrake requires 1050+. What other software can I use with similar features (queueing + presets)? Thanks
ps. I do not have a 980ti YET but I'm planning to buy one this weekend.
You can use any converter which supports encoding via the NVEnc encoder. That may be e.g. Avidemux, StaxRip, or many more. Handbrake supports NVEnc too, but I am not sure about the reasons why at least Pascal architecture is required. So I am not sure if any other converter with NVEnc may have its own limits...
Note: Hardware accelerated video encoding may be faster, but doesn't have to, especially not if your CPU is powerful and has many cores; but it is quite certainly worse in quality, compared to x264 / x265 as CPU encoders from "fast" presets up.
If you have a recent intel CPU, you can als use QuickSync encoders in some converters. Same applies here, though the quality is reported to be a bit better than most other GPU accelerated encoders. Yet, no competitor to x264 / x265.Last edited by LigH.de; 15th Apr 2021 at 02:57.
Best H265 gpu accelerated video conversion software
By Wolluf in forum Newbie / General discussionsReplies: 32Last Post: 18th Jul 2024, 14:13 -
NVENC Accelerated Codecs/Capture Software?
By ENunn in forum Capturing and VCRReplies: 0Last Post: 13th Jan 2021, 02:24 -
GPU Accelerated AV Converter multi-formats for nVidia CUDA Hardware.
By sev7en in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2019, 03:29 -
Hardware encoding vs. software encoding
By Christopher2222 in forum Capturing and VCRReplies: 3Last Post: 29th Jan 2018, 12:35 -
So what's the status on hardware-accelerated rendering for video editing?
By CursedLemon in forum Newbie / General discussionsReplies: 32Last Post: 1st May 2017, 23:56
