Hi folks,
I was using AviSynth 2.6mt and I decided to switch it to AviSynth + 64bits.
Knowing that DirectShowSource would not work I switched to LSmashVideoSource in the Script below.
Code:#Import("M:\temp2\source script2 Dr Paulo Pirej.avs") # Plugins: - RemoveGrain # - MaskTools2 # - Depan + DepanEstimate # - MVTools2 SetMemoryMax(512) SetMTMode(3) LoadPlugin("M:\Temp2\RemoveGrain.dll") LoadPlugin("M:\Temp2\MaskTools2-25.dll") LoadPlugin("M:\Temp2\Depan.dll") LoadPlugin("M:\Temp2\DepanEstimate.dll") LoadPlugin("M:\Temp2\MVTools2.dll") LoadPlugin("M:\Temp2\LSMASHSource.dll") #LoadPlugin("M:\Temp2\RgTools.dll") #mpeg2source("M:\Marcelo 27.5.20\1\01\01-1.d2v") #mpeg2source("M:\Marcelo 999255703 - Fazer\01 ok 19m.d2v") #DirectShowSource("M:\Flavio Itapema 4.11.20 Fazer\02 FI 4capt PanLG.mp4", fps = 25, ConvertFPS = True ) a = LSmashAudioSource("M:\Flavio Itapema 4.11.20 Fazer\02 FI 4capt PanLG.mp4") v = LSmashVideoSource("M:\Flavio Itapema 4.11.20 Fazer\02 FI 4capt PanLG.mp4") AudioDub(v,a) #DirectShowSource("M:\Luis Tonini 14.1.20 - Fazer\01 V14ES10 e.mp4") #DirectShowSource("E:\Tereza Soares 13.8.20 - Fazer\01 TS 8capt V17JVCES10.mp4", fps = 25, ConvertFPS = True ) # para AVI encapsulado AVI Xvid da Avermidia ou MP4 da Aple #DirectShowSource("M:\Neogrid 5-10-17\090 4capt V13SVSDV.avi", fps = 25, ConvertFPS = True ) # para AVI encapsulado AVI Xvid da Avermidia #AVISource("E:\Cleiton\Super 8mm\03\03 ok.avi") #AVISource("E:\Luiz Itapema 23.9.20 - Fazer\18 LI SD8.avi", audio=true) #AVISource("E:\Luiz Itapema 23.9.20 - Fazer\18 LI SD8.avi") # DV AVI #AVISource("M:\Pedro 31-7-18\25 8capt V15ES10SDV.avi", audio=true) SetMTMode(2) #ConvertToYV12() #ConvertToyv411() #Crop(0,20,-0,-30,true) #bob(0,0.5) AssumeTFF() SeparateFields() a=last clense(reduceflicker=false).merge(last,0.5).clense(reduceflicker=false) mot=removegrain(11,0).removegrain(20,0).DepanEstimate(range=2) take2=a.depaninterleave(mot,prev=2,next=2,subpixel=2) clean1=take2.TMedian2().selectevery(5,2) sup1 = clean1.minblur(1).removegrain(11,0).removegrain(11,0) \ .mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2) \ .msuper(pel=2,sharp=0) sup2 = a.msuper(pel=2,levels=1,sharp=2) #bv23=sup1.manalyse(isb=true, truemotion=false,global=true,delta=3,blksize=16,overlap=8,search=5,searchparam=4,DCT=5) bv22=sup1.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=16,overlap=8,search=5,searchparam=4,DCT=5) bv21=sup1.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=16,overlap=8,search=5,searchparam=4,DCT=5) fv21=sup1.manalyse(isb=false,truemotion=false,global=true,delta=1,blksize=16,overlap=8,search=5,searchparam=4,DCT=5) fv22=sup1.manalyse(isb=false,truemotion=false,global=true,delta=2,blksize=16,overlap=8,search=5,searchparam=4,DCT=5) #fv23=sup1.manalyse(isb=false,truemotion=false,global=true,delta=3,blksize=16,overlap=8,search=5,searchparam=4,DCT=5) #a.mdegrain3(sup2,bv21,fv21,bv22,fv22,bv23,fv23,thSAD=499) # << this is the "2-fold" variant interleave(a.mcompensate(sup2,fv22),a.mcompensate(sup2,fv21),a,a.mcompensate(sup2,bv21),a.mcompensate(sup2,bv22)) TMedian2().selectevery(5,2) sup3 = last.msuper(pel=2,sharp=2) bv33=sup3.manalyse(isb=true, truemotion=false,global=true,delta=3,blksize=8,overlap=4,search=5,searchparam=4,DCT=5) bv32=sup3.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=8,overlap=4,search=5,searchparam=4,DCT=5) bv31=sup3.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=8,overlap=4,search=5,searchparam=4,DCT=5) fv31=sup3.manalyse(isb=false,truemotion=false,global=true,delta=1,blksize=8,overlap=4,search=5,searchparam=4,DCT=5) fv32=sup3.manalyse(isb=false,truemotion=false,global=true,delta=2,blksize=8,overlap=4,search=5,searchparam=4,DCT=5) fv33=sup3.manalyse(isb=false,truemotion=false,global=true,delta=3,blksize=8,overlap=4,search=5,searchparam=4,DCT=5) last.mdegrain3(sup3,bv31,fv31,bv32,fv32,bv33,fv33,thSAD=499) # valor Original thSAD=499 LSFMod(strength=60) Interleave() Weave() #stackvertical(a,last) # Alterado por mim. return(last) #-------------------------------------------------------------- # Helper functions function MinBlur(clip clp, int r, int "uv") { uv = default(uv,3) uv2 = (uv==2) ? 1 : uv rg4 = (uv==3) ? 4 : -1 rg11 = (uv==3) ? 11 : -1 rg20 = (uv==3) ? 20 : -1 medf = (uv==3) ? 1 : -200 RG11D = (r==0) ? mt_makediff(clp,clp.sbr(),U=uv2,V=uv2) \ : (r==1) ? mt_makediff(clp,clp.removegrain(11,rg11),U=uv2,V=uv2) \ : (r==2) ? mt_makediff(clp,clp.removegrain(11,rg11).removegrain(20,rg20),U=uv2,V=uv2) \ : mt_makediff(clp,clp.removegrain(11,rg11).removegrain(20,rg20).removegrain(20,rg20),U=uv2,V=uv2) RG4D = (r<=1) ? mt_makediff(clp,clp.removegrain(4,rg4),U=uv2,V=uv2) \ : (r==2) ? mt_makediff(clp,clp.medianblur(2,2*medf,2*medf),U=uv2,V=uv2) \ : mt_makediff(clp,clp.medianblur(3,3*medf,3*medf),U=uv2,V=uv2) DD = mt_lutxy(RG11D,RG4D,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=uv2,V=uv2) clp.mt_makediff(DD,U=uv,V=uv) return(last) } # median of 5 clips from Helpers.avs by G-force Function Median2(clip "input_1", clip "input_2", clip "input_3", clip "input_4", clip "input_5", string "chroma") { chroma = default(chroma,"process") #default is "process". Alternates: "copy first" or "copy second" #MEDIAN(i1,i3,i5) Interleave(input_1,input_3,input_5) chroma == "process" ? Clense(reduceflicker=false) : Clense(reduceflicker=false,grey=true) m1 = selectevery(3,1) #MAX(MIN(i1,i3,i5),i2) m2 = input_1.MT_Logic(input_3,"min",chroma=chroma).MT_Logic(input_5,"min",chroma=chroma).MT_Logic(input_2,"max",chroma=chroma) #MIN(MAX(i1,i3,i5),i4) m3 = input_1.MT_Logic(input_3,"max",chroma=chroma).MT_Logic(input_5,"max",chroma=chroma).MT_Logic(input_4,"min",chroma=chroma) Interleave(m1,m2,m3) chroma == "process" ? Clense(reduceflicker=false) : Clense(reduceflicker=false,grey=true) selectevery(3,1) chroma == "copy first" ? last.MergeChroma(input_1) : chroma == "copy second" ? last.MergeChroma(input_2) : last Return(last) } function TMedian2(clip c) { Median2( c.selectevery(1,-2), c.selectevery(1,-1), c, c.selectevery(1,1), c.selectevery(1,2) ) }
So this error appeared:
[Attachment 58408 - Click to enlarge]
So I decided to insert the RgToos v1.0 32bits in the above script and this error showed up:
[Attachment 58409 - Click to enlarge]
Because of that, I decided to insert the RgToos v1.0 64bits in the script above and it happened:
[Attachment 58410 - Click to enlarge]
Please... Do you guys knows how to solve this problem?
Thank you in advance!!
Has returned with DVD Shrink and Windows 10 Home 64bits
By nest007 in forum DVD RippingReplies: 4Last Post: 17th Nov 2019, 12:22 -
AviSynth Problem
By jseo13579 in forum EditingReplies: 4Last Post: 17th Nov 2018, 10:26 -
AviSynth - hasaudio problem
By queensoft in forum Video ConversionReplies: 18Last Post: 2nd Mar 2018, 09:47 -
Avisynth script problem
By PeterNL in forum Newbie / General discussionsReplies: 3Last Post: 27th Feb 2018, 14:23 -
Avisynth ImageSource Problem
By SameSelf in forum Video ConversionReplies: 7Last Post: 3rd Jul 2016, 21:02
