  1. Hello,
    I a getting StreamingMetadata according to ONVFI's PDF (Application Programmers Guide page - page 71).
    According to the pdf, I'm getting a URL and then use that URL in GStreamer it decodes data and converts them to string but
    couldn't decode the data in my c# code. Can u help me pls?
  2. No experience in that but reading the docs, did you "set up" your metadata stream? Like are you already receiving the corresponding stream in your program?
    It will of course depend a lot on the API/Framework you are using for handline the ONVFI stuff... which nuget package or whatever are you using for it?
