    Apr 2021
    Taking an mkv and attempting to create an iso seemed to be going smoothly until it stopped at 99.5%, right at the finish line it finishes with errors. Worth noting also that I've tried it several times and every time it stopped at exactly 99.5%.
    LOG
    Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1920:1080p Frame rate: 23.976
    H.264 muxing fps is not set. Get fps from stream. Value: 23.976
    H264 bitstream changed: insert nal unit delimiters
    Decoding DTS-HD stream (track 2): Bitrate: 1536Kbps core + MLP data.Sample Rate: 48KHz Channels: 5.1 (DTS Master Audio 24bit)
    Finalize ISO disk
    ERRORS
    Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: [redacted]
    So what's up?
  2. Member Ennio's Avatar
    May 2005
    Netherlands
    Try to demux the mkv with gMKVExtract (requires MKVToolNix installed) into elementary streams and import them into tsMuxer one by one.
    Maybe you want to use latest nightly build https://github.com/justdan96/tsMuxer/releases/tag/nightly-2021-02-13-01-46-27
