is there a wire in the computer that if you dont have it in it will make your computer slower? because i just added a cdrw and i cant get my A: for floppy disk drive to work and my computer is much slower after it? thanks for any help.
did you put it in yourself?
did you perhaps put it on the same wire as your floppy? If so take it off that wire.
put your burner as your secondary master, it might help. -
Just to make sure i'm understood corrctly, don't put it on the same wire as you floppy drive! put it as a master on a second ide wire.
How could you put it on the same cable as a floppy drive, its got a different size connector.
Craig -
I'd never noticed sorry (i usaully learn by trying but i knew that would'nt work for software reasons, didn,t know it would work for physical reasons)
THX for the info Craig
Question on USB Memory Sticks..
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 15th Feb 2012, 09:57 -
Memory upgrade question
By zzyzzx in forum ComputerReplies: 12Last Post: 13th Jan 2011, 17:27 -
Question about Installing Memory to my MotherBoard
By hellfire45 in forum ComputerReplies: 7Last Post: 24th Sep 2010, 22:06 -
ECC pc133 memory question....
By rubberman in forum ComputerReplies: 10Last Post: 7th Sep 2009, 15:26 -
MKV Question (need memory jogged)
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 29th Jun 2008, 12:49
