    Apr 2021
    Seoul,Korea
    Hello
    I have confused one thing for Video Frame extraction.
    I have sample.mp4 video , 15FPS
    https://www.learningcontainer.com/wp-content/uploads/2020/05/sample-mp4-file.mp4
    I tried extracting Keyframe with FFMPEG.
    I get 29 Pictures and I believe I have got 29 I frames. (If I have wrong, Please correct me)
    [Attachment 58370 - Click to enlarge]
    Then I tried extracting specific timeline(10 sec) frame with picture
    ffmpeg -i sample.mp4 -ss 00:00:10 -frames:v 1 test1.png
    This output picture, I can not find same one among my Keyframes I get.
    [Attachment 58371 - Click to enlarge]
    Question: test1.png, What is frame type? Does it one of P or B frame not I ?
  2. VirtualDub shows the frame at 10.00 seconds a P frame (and it matches the test1.png image, and your I frame images all match what VirtualDub shows as I frames). ffpropbe shows the same:
                "media_type": "video",
                "stream_index": 0,
                "key_frame": 0,
                "pkt_pts": 153600,
                "pkt_pts_time": "10.000000",
                "pkt_dts": 153600,
                "pkt_dts_time": "10.000000",
                "best_effort_timestamp": 153600,
                "best_effort_timestamp_time": "10.000000",
                "pkt_duration": 1024,
                "pkt_duration_time": "0.066667",
                "pkt_pos": "813473",
                "pkt_size": "736",
                "width": 320,
                "height": 240,
                "pix_fmt": "yuv420p",
                "sample_aspect_ratio": "1:1",
                "pict_type": "P",
                "coded_picture_number": 150,
                "display_picture_number": 0,
                "interlaced_frame": 0,
                "top_field_first": 0,
                "repeat_pict": 0,
                "chroma_location": "left"
    Why were you expecting the frame at 10.0 seconds to be an I frame?
    Apr 2021
    Seoul,Korea
    Thank you.
    How to get such information on virtualdub? I am not familiar with virtualdub yet. Please let me know.
    "pict_type": "P"
    Actually, the video player I am using(Chrome Web Player), it shows "thumbnail preview" when it has moved mouse point on progress bar. It looks extract thumbnail image every 10 sec from the video source. So, I expect it will be "I" frame.But when I extract "I" frame thru ffmpeg, there is not matched (I frame picture vs thumbnail preview) at all.
    I think the web video player will display thumbnail with P frame. (Please correct me if I have worng)
    Thank you
  4. VirtualDub can show you the frame type below the timeline slider. I don't remember if it defaults to show it. You may have to go into the preferences and enable it. It shows K for I frames, P for P frames, and B for B frames.
    [Attachment 58377 - Click to enlarge]
    If your player is showing thumbnails at 10 second intervals it is not restricted to I frames. The video doesn't have keyframes at 10 second intervals.
    Apr 2021
    Seoul,Korea
    Thank you. It will be very helpful for me. Appreciate!
  6. By the way, you can navigate directly to keyframes in VirtualDub using Shift+RightArrow (next keyframe), or Shift+LeftArrow (previous keyframe).
