Results 1 to 9 of 9
  1. Hello,
    I want to record a live stream of the channel, but I can't do it. Before that, I downloaded only the archive of the channel, which was also .mpd, and the program does not want to record the live stream.
    For recording, I have already tried many programs: youtube-dl (error), m3u8dl (the program is closed), streamlink (the link is protected by DRM), ffmpeg (it was recorded, but there is just interference, you cannot decrypt using the key anymore)
    Stream link ends with .mpd
    Please, help
  2. link with access? or mpd and keys?
    discord=notaghost9997
  3. Originally Posted by notaghost View Post
    The link has a token that allows you to view certain files
    In short, without a token, entering this link will show me an error. If there is a token, then there will be access to the .mpd (the file will be downloaded in the browser)
    I have the keys, but I need to figure out how to record a live stream through some program. If I pull something out of the archive (since this is now a video, not a live stream), then the program easily downloads this video.
  4. It says about the already downloaded video, which they are trying to decrypt. And I want to record a live stream (well, which is coming right now )
  5. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    You can't "record it" (unless you use a screen recorder,like OBS studio). You can only extract chunks of the live stream and then decrypt that.
  6. Sorry, I was wrong. And how to do it?
  7. Raising the topic?
  8. Originally Posted by Egn69217j_ View Post
    Raising the topic?
    https://forum.videohelp.com/threads/401122-Help-with-MPD#post2614109
