Hello.
I have some very old videos that were converted years ago to dvd. They contain precious film of my mom who recently passed away.
In several spots the vertical shake is severe. Here is the video (prime example at the 9:00 mark):
https://youtu.be/M_bvRePlX_k
Can anyone suggest methods to reduce the shake? Anything would be greatly appreciated.
Thank you,
Scott![]()
First of all, if your family still has the film, get it re-transferred. That is a very poor transfer, probably done by pointing a video camera at the screen. The difference between what you have now, and what that film is capable of producing is even more than the difference between old-fashioned standard-definition video and HD.
If you want to remove the shake, then you can use any of several stabilizer programs. Depan works with AVISynth and is free; Deshaker works inside of Virtualdub and is also free. Mercalli is a standalone product (although there are versions that work inside of video editors). It is usually the best, but it is expensive.
You may need to do quite a bit of work on your video before motion stabilization will work. If you walk through the video one frame at a time, and you find that you have duplicate frames, or blended frames (which I can guarantee that you do, even though I am not able to advance one frame at a time on a YouTube video), you'll need to remove them.
I obviously didn't watch all 2+ hours of that film, but I did note that some of the jumping looks like it was caused by a projector that had lost its loop. This is very hard to fix, although it can be done. Here is a sample of one such problem I fixed when the jumping happened in the camera (film wasn't loaded correctly) so it was baked into the film:
Restoration of Jumpy Film
If you get a proper transfer, where one frame of film is transferred to one frame of video, this before/after I produced shows some of what can be done:
Film Restoration: Before/After -
Deshaker in VirtualDub is my go to
https://youtu.be/JltX56MIWn0
edge compensation settings demo that I mention in my deshaker video
https://youtu.be/LzO7kCXWmswLast edited by super8rescue; 11th Apr 2021 at 05:23.
3 problem vhs tapes plus one that plays fine, but footage is shaky 8mm film
By bbmaster123 in forum RestorationReplies: 33Last Post: 1st Mar 2021, 11:25 -
Original file in mp4 format from Reflecta 8mm Super 8mm scanner
By Sajmon in forum RestorationReplies: 0Last Post: 27th Feb 2021, 12:56 -
TRV120 D8 cam won't play most old 8mm tapes, any recommended 8mm camcorders
By analog2digital in forum Capturing and VCRReplies: 1Last Post: 22nd Feb 2020, 12:44 -
Restoring 8mm and Super 8mm transfers
By aoscott in forum Newbie / General discussionsReplies: 11Last Post: 9th Oct 2018, 03:22 -
super 8mm transfer
By tom_nito in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jul 2017, 20:02
