I need some help choosing the right video capture card. I want to be able to hook up my vcr and record tapes to vcd, and I also want to be able to hook up my digital camcorder and record to vcd. I've seen a lot of positive info about the ATI 7500. Is this the right card for me? I know virtually nothing about video capture.
The AIW 7500 is a good card for analogue capture, it has a TV tuner and good 3D graphics capabilities. It does not have a firewire port for DV capture though. You could go to the AIW 8500DV which does have a firewire port and is a much better 3D graphics card, but it costs nearly twice as much. The other option is to get the 7500 and also a seperate firewire card for DV capture. They are only about £20.
I have had two capture cards an ATI AIW 128 pro and a Hercules AIW 7500 (a badged ATI card). I have been pleased with the capture performance of both of them. They can take a while to set up, ATI support is not good. And you may find that you have to play around with the drivers to get everything working correctly. But once they are set up, they are good cards, and in my opinion the best all round solution available.
Craig
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 7th Oct 2011, 23:01 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 15:51 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51
